Wire Recepts. In Series Or Parallel? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-13-2008, 10:47 AM   #31
Rewards Points: 160
Our county inspector requires pigtails for all residential wiring. We don't try to argue with him as he's generally very reasonable, knowledgeable, and efficient. No idea if it's statewide (Oregon) or just this guy's way of doing things. I tend to use a lot of deep boxes so there's plenty of room for all the little "tails".
philS is offline   Reply With Quote
Old 01-13-2008, 11:20 AM   #32
Electrician
Originally Posted by nap View Post
Not neccessarily so.
Some receps are designed to accept 2 wires under a screw (actually they are clamps as opposed to just a screw)
Then they wouldn't be under a screw then would they?
chris75 is offline   Reply With Quote
Old 01-13-2008, 11:50 AM   #33
Originally Posted by JGarth View Post
Those licensed to do electrical work that have integrity would certainly use the pigtail method. The other method is considered to be the work of the low end (schlock) installers. Just to save the cost of a few wire nuts, pure and simple.
I have to agree with Speedy on this one.
The recs we use are UL listed and approved for 20 amp feed through.
Are you saying that UL is run by a bunch of "schlocks"?
Where did you go to school and work to become so much smarter than them?
Master Electrician
jwhite is offline   Reply With Quote
Old 01-13-2008, 01:27 PM   #34
Electrician philosopher
Not grumpy at all, just plain truthful. I know bs when I see it. You are not nearly educated or experienced enough to pull that .02 psych bs.
This is not the first time you stalked me here. You have to get a life, instead of stalking people on the net. I realize this site is your life, I have seen your type many times, so I should be cognizant that all you have to look forward to is posting here.
As far as wiring, more than a couple of you will ever do in your entire lifetime. Granted, I've been retired for a few years, but I know inferior wiring practices when I see them.
I'd be more than willing to provide the owner/administrator of this website with my name, phone number, PE license no, and Master Electrician Lic no.
I would assume you would also do the same, if you have the credentials.
Have a nice day,
JGarth
Definitely a little tense, Mr. Garth. Just got a new camera. If I can figure out how to post pics would ya'll be interested in my "inferior work"? I've wired a blue million homes "perfectly" and am engaged in my 14 MO in commercial work. I am headed to Athens GA to wire a hospital Monday.
Andy in ATL is offline   Reply With Quote
Old 01-13-2008, 02:10 PM   #35
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
must be a pretty small hospital if all it will take is Monday
JGarth, I presume your masters license is not in your current state of residence as listed below your name, correct?
Old 01-13-2008, 02:15 PM   #36
Rewards Points: 266
Andy, I know your work isn't inferior but that doesn't mean we don't like pictures here!
junkcollector is offline   Reply With Quote
Old 01-13-2008, 04:13 PM   #37
waiting for spring
arichard21's Avatar
Rewards Points: 150
This is one thing that has always bothered me... the fact that people can't just admit that there are 2 ways to do things sometimes... and neither one is the ONLY way. That screams ignorance to me.
arichard21 is offline   Reply With Quote
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 07:02 PM
Stove Top wire capt2 Electrical 8 10-05-2007 02:41 PM
Running speaker wire parallel to electrical wire spyguy Electrical 3 02-21-2007 03:10 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Parallel vs. Series Circuit johnson217 Electrical 1 06-19-2005 11:03 PM
