Wire Re-identifying - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 12:17 AM   #1
Rewards Points: 192
Wire Re-identifying
At what AWG can I use a black wire for a nuetral if I re-identify it with white tape?
Rick
bcgfdc3 is offline   Reply With Quote
Old 04-12-2013, 12:23 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Rick
For the cable* it can be any size but for indivual conductors it have to be 16mm2 ( #6 AWG ) or larger so that pretty much set with NEC codes but I am not too sure with Canada side if you are in there the rules may apply little differnt.
Merci,
Marc
* like NM ( Romex ) or UF ( underground feeder ) cables even a hevey duty extendison cord can do this as well.
Old 04-12-2013, 12:30 AM   #3
Rewards Points: 192
Thanks,
I am in the US and was looking for individual THWN type wire reference.
Thanks again
Old 04-12-2013, 06:15 AM   #4
eastcoastsparky's Avatar
Rewards Points: 150
#6 awg or larger can be reidentified as a nuetral
eastcoastsparky is offline   Reply With Quote
Old 04-12-2013, 11:16 PM   #5
Or remarked as phase ( only with oringal black conductor ) conductor of other colours.
Merci,
Marc
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
