Wire Plates To Protect Wire In Wall? Do I Need Staples On Horizontal Runs? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2014, 07:14 AM   #1
Rewards Points: 384
Wire plates to protect wire in wall? Do I need staples on horizontal runs?
I have a wall that is the interior wall of an office and the outside wall of a playroom. I'm running outlets for both sides of the wall and the code says the wire should be 1 1/4 from the surface which seems really close. Is this okay or do I need plates to protect the wire?
Same wall is 8' long, do I need staples along the part that runs horizontally through the holes?
RyanD is offline   Reply With Quote
Old 01-05-2014, 07:17 AM   #2
Licensed electrician
Rewards Points: 1,480
Staples are not needed when the wiring runs through bored holes.
The 1 1/4 inches from the surface is the minimum distance. Holes drilled in the center of a 2x4 would not need a plate.
Old 01-05-2014, 07:56 AM   #3
Rewards Points: 13,450
If your using 1-1/4 drywall screws and you have 1/2 drywall on the wall the screws only going into the wood about 3/4".
Adding a wall switch but found a random "hot" blue wire crzycicada Electrical 8 10-13-2012 05:17 PM
Metal wire staples vs. Plastic wire staples tripower Electrical 14 02-18-2009 05:23 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
