Wire For Outlet? 12-2 Or 12-3 - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 02:33 PM   #1
Wire for outlet? 12-2 or 12-3
I am removing a wall and have to re-route some wiring. My plan is to install a junction box and re-route the wire as necessary. The question I have is what type of wire do i need for an outlet. The existing wire is stamped 12/3? (from what I can tell; hard to read). I thought that 12-2 was what I would need for an outlet. Is this correct? Does it make a difference if the outlet is in a series of other outlets?
Bahuffma is offline   Reply With Quote
Old 08-22-2011, 02:40 PM   #2
Licensed electrician
Rewards Points: 1,018
XX-2 would have one hot conductor. XX-3 could have 2 hot conductors, a black and a red.
Typical usage for xx-3 is 3 way switching or when 2 circuits are run to the same location in one cable and can be split off at a junction box.
Old 08-22-2011, 03:27 PM   #3
Thanks Jim! That's what i thought..just don't know why the cable would be stamped 12/3?? There are only three wires (not sure of color..not at home).
Old 08-22-2011, 04:08 PM   #4
another question...maybe i am not understanding this..would you use 12/3 if you are running a number of outlets in line?
Old 08-22-2011, 04:45 PM   #5
Code05's Avatar
Rewards Points: 1,104
It should be 12/3 w/ground. Black,red,white and a bare one.
Code05 is offline   Reply With Quote
Old 08-22-2011, 04:46 PM   #6
Code05's Avatar
I do not have a clue what you are saying.
Old 08-22-2011, 05:53 PM   #7
You typically wire receptacles in a A to B to C to D pattern. You only need xx-2 cable unless you need another hot that is switched along with the constant hot.
Old 08-22-2011, 06:02 PM   #8
you wouldn't unless:
1) the receptacle is semi controlled ( top or bottom portion controlled by a switch)
2) you have two circuits in the same area ( Black on one breaker, red on another breaker and sharing a neutral) That way you only have to run one 3 wire cable instead of two 2 wire cables.
Edit: im not sure if you're actually talking about receptacles or lighting outlets..alot of ppl call recpetacles, "outlets"
MitNotrof is offline   Reply With Quote
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
