Wire Options For A 70 Amp Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2008, 03:28 PM   #1
Master Procrastinator
Wire options for a 70 amp subpanel
I am going to be installing a 70 amp subpanel for my new attached garage. Could you guys tell me what options I would have as far as wire to feed it with? I would like to avoid having to run conduit if possible. It will be around a 40 foot run to the sub. Can I use a 4/3 romex? Or is there a better option.
Thanks fellas
mtaviator is offline   Reply With Quote
Old 01-11-2008, 03:30 PM   #2
Licensed Pro
Use 6/3 Romex protected by a 60A breaker. You'll never miss the other 10A.
Old 01-11-2008, 03:52 PM   #3
Thats not a bad idea.
On that subject-
I was thinking of installing a couple 220 outlets for 2 reasons.
1- to run my table saw off at roughly 8 amps of 220 power.
2- to power a mig welder down the road (that I don't own yet).
That leads me to my next Q.
Any recommendations at to what style of plug and amp rating to use for a modest sized mig welder, I haven't looked at the plugs on any. 20 amp? 30 amp?
Old 01-11-2008, 04:43 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Have you purchased that load center yet, if so how many spaces for full size breakers does it have?
Old 01-11-2008, 07:36 PM   #5
No haven't bought anything yet.
Old 01-11-2008, 08:46 PM   #6
Electrician
I personally would just buy 2/3 AL ser, it's cheap enough and will give you 90 amps, which will be good for future tools you don't own yet... As far as the subpanel, I would go with a 24 circuit panel.
chris75 is offline   Reply With Quote
Wiring 100A subpanel nebulous Electrical 9 08-29-2007 03:41 PM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 01:58 PM
Can i add a subpanel fed by 10/2 wire? qst4sno Electrical 25 04-25-2007 06:14 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
