Wire Nuts - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 09:13 PM   #1
Wire Nuts
I just installed new lights above my mirror in the bathroom and black and white wires come out of the fixture on the left side and the box that has the hot and neutral wires are on the right side, so when I wire nut the wires together, they don't make back into the box. Is it OK to have the wire nuts behind the fixture?
howard.wheaton is offline   Reply With Quote
Old 02-20-2011, 09:49 PM   #2
Civil Engineer
Rewards Points: 4,566
If I understand what you are saying, you have wire nutted the hot and neutral outside the box. If that is what you are saying, no it is not code, and it is not safe. All connections must be made inside an approved box. If the wire is not long enough, your options include running a new wire from the panel to the fixture, or installing an accessible junction box to make the connection.
Daniel Holzman is online now   Reply With Quote
Old 02-20-2011, 10:37 PM   #3
Do you know how the wires are terminated within a fixture? My only option would be to run longer wires from the fixture so it reaches the existing box.
Old 02-21-2011, 01:49 AM   #4
Scared Electrician
Saturday Cowboy's Avatar
this sounds really messed up. pictures please?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 02-21-2011, 02:28 AM   #5
" Euro " electrician
frenchelectrican's Avatar
First thing pics please .,
Second thing some lightbar or luminaires itself have build in junction box room so some can get awawy without a junction box however that is kinda a grey area depending on how it run.
Merci,
Marc
Old 02-21-2011, 08:34 AM   #6
Rewards Points: 1,442
What I would do: Open the back of the fixture. Cut a length of 12-2* cable to reach from the junction box to enter the fixture through its wire opening. Inside the fixture, splice the wires together.
Caution, the cable must not pass through an opening with sharp edges. You may need to enlarge the wire opening to fit a larger grommet inside so the (larger) 12-2 cable can pass through. The fixture may have a 5/8 inch round hole with a bend-off cover in which you can put a Romex cable clamp as an alternative to using the small hole where the fixture's own wires came out.
* If the light is fed by a 15 amp 14 gauge cabled circuit that does not serve receptacles in the bathroom then you can use 14-2.
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 09:36 AM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 05:24 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Are wire nuts needed? mopowers Electrical 11 12-17-2009 12:44 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
