-   -   Wire Nuts (http://www.diychatroom.com/f18/wire-nuts-13340/)
handy man88 11-12-2007 02:32 PM
Wire Nuts
Per code, how many conductors are allowed to be connected via wirenuts? I speaking of 14 gauge wire.
HouseHelper 11-12-2007 02:53 PM
Depends on the wirenut. Permissible numbers and gauge combinations are listed on the wirenut packaging.
Andy in ATL 11-12-2007 03:45 PM
Handy, As many as you can cram under 'em!:laughing:
Just kidding. Look at the package, As HH suggests. Also, use some common sense. Install the wirenut. Can you see bare copper? If, when you tug on the wirenut hard, does the tap come apart or does it stay together? Do you "feel" good about it after it is done?:huh:
handy man88 11-12-2007 05:30 PM
Hello.
I didn't buy the wirenuts. I was connecting up some smoke detectors that were not connected. In my basement, I had one that was powered, and two unpowered. Upon removing the one with power, I discovered a 14-3 wire that was not connected, so I connected this to the loop. The other smokes turned on. The wire nuts seem heavy duty, with flanges.
The main smoke had one in and one out, one for the interconnect, and another one, and then the stranded wires for the smoke's connector. That makes 4 conductors and one stranded wire for the smoke's connector for 2 wire nuts (hot and neutral). The wire nut felt fine after it was screwed together. Just wondering if there's any chance of overheating.
Andy in ATL 11-12-2007 05:40 PM
The key to electrical connections is TIGHT. Let me repeat. TIGHT.
If you are confident all the wires are connected to one another TIGHTLY then there is no chance of overheating from the wirenut.
Loose connections burn down homes. Arcing is bad.:yes:
