Wire Nut For 5 Wires??? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 04:50 PM   #1
Wire nut for 5 wires???
Here is a picture of how I plan on wiring a couple switches in my garage in a double gang box. Can you guys verify that it is correct? One of the top cables supplies the power and the other top cable takes power to the garage opener. The three switches are for different light circuits.
Is it okay to wire nut the (5) 14g neutral wires together? What color nut should be used?
Thanks!!!
mopowers is offline   Reply With Quote
Old 03-16-2010, 04:59 PM   #2
Master Electrician
Rewards Points: 3,918
Looks correct to me assuming that left hand device is a duplex switch. I use Ideal tan and red wire nuts. Either color should work ok for you.
brric is online now   Reply With Quote
Old 03-16-2010, 05:08 PM   #3
Rewards Points: 1,010
Tan ideals. Here is a chart http://www.idealindustries.com/media...mbinations.pdf
Most wire nuts will have a chart on the back
Anti-wingnut is offline   Reply With Quote
Old 03-16-2010, 06:58 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
Tans. Reds. Red/Yellows. Greys.
Old 03-16-2010, 07:35 PM   #5
Thanks folks!
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
How do I wire these switches? keano016 Electrical 2 10-07-2009 10:19 AM
Do ground wires require "green" wire nuts? epeterson777 Electrical 4 03-14-2009 11:49 AM
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
