Wire Next To Shower Valve - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 10:33 PM   #1
wire next to shower valve
i am remodeling a bath. i replaced the tub with a deeper one. i am ready to put in the shower valve and have a question.
the old shower valve was 4inches lower than the new one i am putting in due to the increase in tub depth. there is an electrical wire (romex) that ran above the old valve. my new valve location will be right in front of the wire. the back will actually touch the wire. i am wondering if the wire is ok or if it needs to be moved so that it remains above the valve.
emmsvs is offline   Reply With Quote
Old 07-22-2012, 10:42 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If the cable is metal it shouldn't touch the valve or any copper.
Old 07-22-2012, 11:11 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Since its NM type wire, I wouldn't fuss over it...
Old 07-22-2012, 11:13 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
I'd try and bend the wire out of the way so it's not touching, but that's it.
Old 07-22-2012, 11:14 PM   #5
k_buz's Avatar
The "(romex)" was edited after I responded.
Old 07-22-2012, 11:14 PM   #6
E2 Electrician
lol...
No flow from Delta 1700 shower valve after cartridge replacement billyjoe Plumbing 11 04-24-2016 03:42 PM
Replacing Shower Valve suncowiam Plumbing 18 06-01-2011 12:49 AM
New shower valve, no hot water? Chris112 Plumbing 0 03-19-2011 07:21 PM
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 06:03 PM
Shower mixing valve replacement w/galvanized pipe rsaritzky Plumbing 3 05-13-2009 11:11 AM
