-   -   Wire Multiple Lights controlled by 4-way Switch? (http://www.diychatroom.com/f18/wire-multiple-lights-controlled-4-way-switch-32042/)
mfleming 11-17-2008 09:48 AM
Hello.
I'm planning on installing 6 pot lights and I want them controlled by 3 switches (4 way wiring)
This is what I was thinking.
Power(2-wire #14) --> 2 Gang 3"x2-1/2" (1 3-Way Switch) --> 3-Wire#14 --> 2 Gang 3"x2-1/2" (1 4-Way Switch) --> 3-Wire#14 --> 2 Gang 3"x2-1/2" (1 3-Way Switch) --> 2-Wire#14 --> PotLight1 --> 2-Wire#14 --> PotLight2 --> 2-Wire#14 --> PotLight3 -->
This is in Canada. I'll be using double face plats with 1 side solid and the other open for the switch due to box fill calculations.
Does that look correct?
Also in regards to wiring the the lights due I use the black wire coming in and the black wire going out and add a short 4"+/- black wire and merit them all together than connect the end of the 4" black wire to the light or can I do away with the extra 4" wire? (black or white wires)
AllanJ 11-17-2008 10:16 AM
Looks right to me.
If the existing wire from the light socket will reach, then you may tie that directly to the other wires entering the connection box for the pot light. No extra 4 inch piece needed.
jamiedolan 11-17-2008 12:03 PM
Originally Posted by mfleming (Post 186277)
Hello.
Sounds right to me. Use all the same brand of switch, makes it easier to figure out the correct placement of the wires.
Jamie
joed 11-17-2008 01:09 PM
You shouldn't need double boxes to meet box fill. You only have two cables going into each box. How did you determine your fill count?
rgsgww 11-17-2008 02:02 PM
Looks good. Its always 3 way at beginning, 4 ways in the middle, 3 way at end.
You don't need the double boxes. Or are there more wires?
Wildie 11-17-2008 02:41 PM
The Ontario code allows 7 conductors in a standard, single gang switch box.
Plus any grounds from NM cable.
As already noted, 2 gang boxes wouldn't normally be required!
darren 11-17-2008 04:40 PM
I will use your middle box as this is the box with the most wires.
2 14/3 with a switch
6 wires=6 conductors(you don't count the ground wire only insulated wire)
1 wire nut(neutral)=1 conductor
switch=2 conductors
So a total of 9 conductors and that will fit into a 3x2x3.
Now if Ontario has there own rules for this it could be different
Wildie 11-17-2008 06:12 PM
switch=2 conductors
All he needs is a 14/3 in and a 14/3 out for a total of six.
The red and blacks connect directly to the switch and as you say the white neutrals are wired together!
220/221 11-17-2008 06:27 PM
Or, on the service call I did today, the blacks and white go to the switch and the reds are wired together for the neutral :jester::jester::jester:
This was relatively NEW construction. It functioned and had nothing to do with the problem (loose wire on terminal) but really confused me.
Billy_Bob 11-17-2008 06:27 PM
Here is a diagram and just parallel additional lights on to the end...
http://www.electrical-online.com/Fall204.gif
darren 11-17-2008 06:45 PM
I was figureing out his box fill for him, obviously there is physicaly only 6 wires but i was takeing into account his switch and marrette.
joed 11-17-2008 07:42 PM
switch=2 conductors
One wire nut counts as 0. 2-3 counts as one.
mfleming 11-17-2008 11:41 PM
My current gang boxs are 12.6 for the fill. I used a fill calculator I go off the net.
2 for each conductor, (2-14/3 = 6 6*2 = 12) So 12 plus the switch, plus the merrit and I'm over 12.6. They are standard Iberville gang boxes from Home Depot on Rona.
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
joed 11-18-2008 07:49 AM
You need the single gang boxes with the bulges on the sides. The bulges give added capacity.
Here it is. The 3 inch version has a fill cap of 18. The 2.5 inch version has fill cap of 16.
http://www.homedepot.ca/wcsstore/Hom...BC3004LH_2.jpg
chatterbass 11-18-2008 10:46 AM
1 Attachment(s)
here is another. I just like the way it looks.
