Wire Motor For Reverse Operation - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2012, 07:20 PM   #1
Wire motor for reverse operation
I have a LEM .35hp meat grinder that did not come with reverse. It is a PITA to use and not have reverse. It is a 120v 250w motor, w 2 caps. There is no schematic on the cover, so I have no idea what which wire goes to where. I plan on using a DPDT switch to reverse it. on-off-(on or mom) switch. I have attached pictures of the motor wiring. White/black come in then go into motor. White comes out of motor then to larger cap, other wire from large cap goes to red (into motor). Red comes out of motor into smaller cap, second wire to small cab is blue going into motor.
http://i1086.photobucket.com/albums/...n/IMAG0021.jpg
http://i1086.photobucket.com/albums/...n/IMAG0020.jpg
http://i1086.photobucket.com/albums/...n/IMAG0022.jpg
Any help would be appreciated.
speedee12 is offline   Reply With Quote
Old 05-04-2012, 10:30 PM   #2
Missouri Bound's Avatar
What makes you think that motor is reversible? Not all motors are, in fact most are not. You need a schematic for that motor.....that will tell you if indeed it is reversible and also what the voltage requirements are.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
plummen (05-04-2012)
Old 05-05-2012, 02:35 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Post the model number of that motour and looks like a IEC format and this one I doubt that is a reverseable type at all.
So look at the nameplate to see what it say on that.
Merci,
Marc
Old 05-05-2012, 09:27 AM   #4
Per the name plate
Single phase induction motor
Type YYL63M-4B5
VOLT 120V
FRE 60HZ
KW .25
DUTY TYPE S1
This was the only markings that I could find, but I could try to look a little more (disassemble the motor more)
Old 05-05-2012, 10:00 PM   #5
Some fractional motors can be reversed and some not!
The ones that can be reversed will have both the run and start windings brought out to the terminal board.
The start winding leads have to be interchanged in relation to the run winding leads.
A double pole, double throw switch is required if you wish to switch back and forth.
http://www.ehow.com/how_8037728_chan...ase-motor.html
Old 05-05-2012, 10:14 PM   #6
So do you think that if I switch the red/blue wires on the smaller cap it will run in reverse?- the smaller cap is "floating" in the box and has push connectors, while the larger cap is screwed down and has solid connectors.
Basically what wires are for start and which do you think are for run?
I am not sure if you can tell by the pix but the one cap is smaller and insulated w foam. Why the different size/insulated cap?
Old 05-06-2012, 12:23 AM   #7
I searched capacitor start motors and didn't really find an answer to your question. In some designs an integrated circuit is used to control start up.
Its had for me to see, but it appears from your photos that you may have an i/c built into yours.
I trained as an electrician and just have a general idea of motor theory. A motor specialist may be able to advise you properly.
Its my hunch, that if its possible to install a reversing switch on your motor, that the manufacturer would be the best source of how to do this.
Its my uneducated opinion that it wouldn't be possible with this particular setup.
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
