Wire Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 04:52 PM   #1
wire motor
how to wire dayton 6k3321ba 1hp motor 208/230 1 ph
toddg is offline   Reply With Quote
Old 09-10-2012, 05:11 PM   #2
Resi EC
Rewards Points: 252
Is it 8 amps on the name plate?
Gac66610 is offline   Reply With Quote
Old 09-14-2012, 11:36 PM   #3
Idiot Emeritus
Rewards Points: 1,492
6k3321ba isn't a Dayton number but 6K321 is.
It's a 1HP motor with thermal protection.
To connect it for 208-230, splice P1 to one of the incoming lines. P2 is capped off (not connected to anything).
If you want it to turn clockwise looking at the back of the motor (with the shaft pointing away from you), splice T2, T3, and T5 together. Splice T4 and T8 to the other incoming line.
If you want it to turn the other direction, splice T2, T3, and T8 together. Splice T4 and T5 to the other incoming line.
Rob
micromind is offline   Reply With Quote
Old 09-14-2012, 11:36 PM   #4
Idiot Emeritus
Double post.
Need help replacing HVAC condensor fan motor - 3 wire old to 4 wire new jmcinni HVAC 4 08-18-2012 03:11 PM
How wire an HP 1.0 Motor Dayton ? Conquistador Electrical 5 01-27-2012 07:34 PM
wire leads on Reliance Motor abnormalnorman Electrical 13 06-30-2010 09:49 AM
New fan motor going out? DavidI HVAC 5 06-23-2010 10:38 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
