Old 10-04-2012, 08:48 AM   #1
wire limitations between studs?
I have relocated a door that goes from my house into my garage. So I have the first section to the right of the door with the sheetrock removed. I have a 2 gang box on the inside room nailed closest to the door going out to the garage. It is attached to the left stud. I need to put the 2 gang switch box on the garage side in that same space - so I was going to attach it opposite of the existing switch box - so it would be on the right stud. Is there a limit to how many 14/2 wires I can run up inside that space? It may be like 3 up the left stud and 3 up the right stud. Is this OK?
Hope this makes sense.
tbone2004 is offline   Reply With Quote
Old 10-04-2012, 08:51 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Hard to picture with what you wrote. Can you post some pictures showing what you are talking about.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 10-04-2012, 08:57 AM   #3
Not at the moment.
But basically - in the space between studs (16") can I have (2) 2-gang switch boxes? One faces in to the room, the other faces out to the garage side. I was curious if there are restrictions to having two switch boxes sharing the space between studs. One will be on the left stud and one on the right stud.
Old 10-04-2012, 09:13 AM   #4
Julius793's Avatar
There are no restrictions
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 10-04-2012, 10:27 AM   #5
Lic Electrical Inspector
electures's Avatar
No limit. Just use stackers.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 03:41 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
