Wire A Lightswitch So It's Always Off? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 09:17 AM   #1
Wire a lightswitch so it's always off?
Hello,
I'm interested in disabling a rocker light switch so that the light it operates is always turned off. Is there a safe way to do this without having to call an electrician? Thank you for your help!
beetrix12 is offline   Reply With Quote
Old 02-01-2011, 09:19 AM   #2
Rewards Points: 1,452
You can do it yourself. Turn off the breaker (and test the switch that it does not work).
Remove the switch, take off one wire from the body side, tape the wire end, put the switch back. (Refinement, put a label on the loose wire so the next homeowner knows what it was for.)
Alternative method. Take the lamp out of the light fixture.
Old 02-01-2011, 09:34 AM   #3
Licensed electrician
Rewards Points: 1,278
The code may require a switch controlled lighting outlet in the room. Removing the switch may create a code violation.
What room is this in?
Speedy Petey (02-01-2011)
Old 02-01-2011, 10:50 AM   #4
joed's Avatar
Rewards Points: 12,016
Use a wire nut not tape.
The Following User Says Thank You to joed For This Useful Post:
Old 02-01-2011, 03:55 PM   #5
WaldenL's Avatar
Rewards Points: 268
Not sure what you mean by the "body side", but disconnect the load side, not the line side. If you think of a switch as having power come in one wire, and then when it's on, power goes out the other wire. The wire you want to disconnect is the wire the power goes OUT, not the one it comes in. Which is which may not be obvious, so you'll need a tester of some kind. But this way there isn't a loose wire in the box that's live.
And yes, don't use tape, use a wirenut, even though you're only nutting one wire.
WaldenL is offline   Reply With Quote
Old 02-01-2011, 04:29 PM   #6
At my work we have several switches that are to remain on at all times.
We found a nifty cover at the hardware store. You remove the screw from the light plate cover, and then screw this over the plate. It's now impossible to touch the switch, without removing this screw down cover.
Before we found these nifty covers, we used masking tape, but someone kept taking the tape off.
pyper is offline   Reply With Quote
Old 02-01-2011, 04:49 PM   #7
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 72
Yep, this.
Or if you want to laugh at the face of danger, just use foil on the end, and arrange it so the foil is not touching any surface inside.
Another thing you can do is wire nut both wires, remove the switch and just put a blank faceplate, that way you don't have a switch there for nothing.
Old 02-01-2011, 06:05 PM   #8
Body side -- Not the green screw at the end of the metal strip (yoke) attached to the switch body.
Wire nut -- If you don't have any wire nuts small enough to stay on and large enough to cover the bare wire end, then you will need to use some tape.
Tags
lightswitch off
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 01:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 10:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
