Wire Length In Range Outlet Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 08:17 PM   #1
Wire length in range outlet box?
Just upgraded from 100 amp fuse panel to 200 amp siemens breaker panel. Did all the work myself from weatherhead to panel. Service inspection done and panel energized. Switching my drops over but rewiring range for 4 conductor. Using old flex and running new 6/3 NM-B with 4" X 2 1/8" box , raised cover, and 50 amp flush mount outlet. The question is (finally) what is the requirement for wire length inside box? Trying to get 3 6" leads and the ground coiled up inside the box is nearly impossible and doesn't seem correct. Thanks in advance. Ken
Block13 is offline   Reply With Quote
Old 09-21-2011, 09:30 PM   #2
Electrician
Rewards Points: 760
You have to fit them in there to work with the plug, fold the wire to the back and leave just enough to get under the terminal screw. You usually have to keep wires from the middle of the box and wrap them around the outside of the box.
You can't just put them on and push them in like you would with a plug.
darren is online now   Reply With Quote
Old 09-22-2011, 11:47 AM   #3
Rewards Points: 58
You need the right type of box. A regular 1900 box and raised plate does not provide much room. They make a box designed just for this application. It is deep and requires no ring or raised plate. The receptacle screws directly to the box. Ask for a metal range box at the store. They should know what you mean.
Old 09-22-2011, 06:45 PM   #4
Electrician
Rewards Points: 760
It will be a 4 11/16x 4 11/16 box you will need.
Old 09-22-2011, 06:55 PM   #5
Code05's Avatar
Rewards Points: 1,104
Use a surface mount receptacle, no box needed.
Code05 is offline   Reply With Quote
Replacing outlet - no ground wire clydesdale Electrical 17 12-18-2011 03:29 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
220, two wire, hard wire, to 4 prong outlet jasesselstyn Electrical 9 11-27-2010 09:59 PM
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-15-2009 12:17 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
