Wire Length AFCI Breaker Install Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 01:15 PM   #1
Wire Length AFCI breaker install issue
So Im'm going to replace some of my existing breakers with AFCI breakers. The wires come in the top of the panel, with the neutral immediately splitting off to the bus bar. Given this, the neutral will be too short to reach all the way down to the new AFCI breaker. The only way I know to handle this is to setup a junction box on the wall outside of the panel, splice a new wire in the junction box, and run the new wire in the panel, making appropriate connections - any other ideas? (I'm not splicing wires inside the panel as I assume that is a no no and against code)
Thanks, JC
205bhamjim is offline   Reply With Quote
Old 02-24-2010, 01:34 PM   #2
Licensed electrician
Rewards Points: 1,258
Your location in your profile is not filled out.
Splices are not allowed in a panel by the CEC. In the US you can splice in the panel. This is commonly done on panel changeouts.
Old 02-24-2010, 02:27 PM   #3
location
sorry - I'm in Birmingham, AL
Old 02-24-2010, 02:59 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 232
you can splice inside the panel, but a few questions first.
How old is the house?
Do you have any multi wire circuits?
What is compeling you to install afci breakers now?
Old 02-24-2010, 03:32 PM   #5
The house was built in 67, we just bought it last spring. The panel has been changed out inthe last few years but there are many 14/2 wires running on 20a breakers. As i need to change those down to 15a anayway, I thought I might as well use afci, to add a little extra protection. Will also help me sleep better at night.
Old 02-24-2010, 03:33 PM   #6
oh i left out one of your questions. None of the breakers I will be changing are on multo wire curcuits. Just standard 14/2 breaker change and maybe a a 12/2 (20a) also.
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 04:14 PM
20 amp breaker on 10/3 wire Duane 70 Electrical 6 09-16-2008 02:02 PM
Tub surround install issue OriginalSterm Remodeling 4 09-11-2008 08:11 AM
breaker issue, need help!! kwal63 Electrical 4 08-11-2008 07:11 PM
replaced furnace blower now breaker issue Kurr HVAC 5 01-25-2007 10:22 PM
