-   -   wire leads on Reliance Motor (http://www.diychatroom.com/f18/wire-leads-reliance-motor-74410/)
abnormalnorman 06-22-2010 08:57 PM
I recently picked up a Reliance Motor and need help figuring out which leads go together to make this unit work. The following info is the best I can give off the motor tag as there is a lot of scratching on it. I tried the Reliance web site and could not find the info on this motor.
Identification 503069 ?? W
Type CU
FR R564
HP 1.5
RPM 1725
Volt 230
Amps 10
AMB 40
Time Rating 30 min
?? Class A
There are 6 wire leads on this as follows. P1 T1 T4 T6 T7 T8 Leads T4 and T8 were wrapped together..all others were loose.Any help would be appreciated.
goose134 06-22-2010 11:13 PM
Ou est, Marc?
frenchelectrican 06-23-2010 11:39 PM
Thanks goose :)
Anyway abnormalnorman.,
Give me a day or two I will able find the info on this motor due sound like one of the older style motor with non standard connections so I will check with them to see what they can dig up.
Merci.
Marc
J. V. 06-25-2010 10:10 AM
Its a proprietary motor and you need to call Reliance or Baldor (they are one in the same now) and give them the ID number. They will then give you a phone number for the manufacturer that owns that particular motor. The owner may give you the connection diagram. Maybe. Hopefully Marc can come up with it for you. I tried yesterday to figure it out but you do not have a standard motor.
abnormalnorman 06-26-2010 10:16 AM
Thanks J.V. I will give them a call later next week. In running a continuity check I discovered T6 & T7 are connected, as well as T1 & T4. P1 & T8 are loners. There is also a reset button on this motor, FWIW
J. V. 06-27-2010 10:27 AM
The problem is you are missing several wire numbers and they did this for a reason. To make you call them.
Where is T-2 - T-3 - T-5 and P2?. Without a diagram I would not energize it just yet.
abnormalnorman 06-27-2010 03:31 PM
OK...I will NOT apply any power to this until I hear back from the folks at Baldor on this unit.Thanks everyone for chiming in on the matter.
Red Squirrel 06-27-2010 03:45 PM
You could try to get the motor to spin up fast using another motor (mechanically connected) and then test the voltage output of the leads. Might give you an idea of what is what. You'll know which leads want higher voltage then others, at least.
frenchelectrican 06-27-2010 10:19 PM
I will call them first thing in the moring or afternoon due I am in Paris France time zone so you should hear from me withen 24 hours or less.
Merci,Marc
plummen 06-27-2010 11:29 PM
what color are the wires?
abnormalnorman 06-28-2010 08:26 PM
All the wires are black. More info as I open a few things up on it. From what I can see the P1 runs to the Reset button. When I connect an Ohm Meter to various leads the only reading I could get was from T1 to T4, a reading of 1.4 I did check P1 to all the other leads and found nothing there. I did notice when checking for continuity that P1 would show continuity to T4 as well as to T1 when I held the reset button in.Waiting here to hear back from the folks at Baldor...
J. V. 06-29-2010 09:45 AM
Where are you located and what field office did you call? They should be able to tell you right away. Call this number and ask them. This is Baldor's Atlanta office. Ask for Judy or JoEllen. 770-772-7000.
abnormalnorman 06-29-2010 09:55 PM
Actually, I emailed them from thier web-site.But thanks for the phone number, I will simply call if I don't hear back from them.
J. V. 06-30-2010 09:49 AM
They are not going to respond to an email. :whistling2: You are an end user.
