Wire Labels - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 03:42 PM   #1
Rewards Points: 1,062
Question
wire labels
as i'm nearing the end of my wiring project, i realize i have created a monster -- and i have uncontrollable chaos. i recall seeing little write-on self-adhesive laminated tags that wrap around a cable and have enough of a label to write on, kind of like the warnings on blow dryers but you can write on them.
anyone know the specific name for this that i can search online because "electrical label" was too vague, seems like.
my goal is to label every cable every 4-5 ft and know instantly which is which. my cabling is pretty neatly laid out (no intertwining cables or even crossing one another), all as parallel as can be etc. i am pretty OCD but i like that cause i almost get seizures in chaotic situations. everything must be under control...
kind of like what i tried to illustrate
Old 09-16-2012, 04:00 PM   #2
Licensed electrician
Rewards Points: 1,294
Brady makes many label styles. Panduit may also have something to choose from.
Old 09-16-2012, 04:32 PM   #3
Rewards Points: 13,300
A Sharpee works for me. Cheaper and the tags not going to fall off.
Speedy Petey (09-16-2012)
Old 09-16-2012, 04:43 PM   #4
Sharpee on what ? cable itself ? no, i can't write letters that small.
Old 09-16-2012, 05:14 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Really? That's SOP in the trade.
The Following User Says Thank You to Speedy Petey For This Useful Post:
frenchelectrican (09-17-2012)
Old 09-16-2012, 06:31 PM   #6
what's SOP ?
Old 09-16-2012, 06:34 PM   #7
standard operating procedure.
amakarevic (09-16-2012)
Old 09-16-2012, 07:48 PM   #8
Missouri Bound's Avatar
If you can't write that small...just make a chart and number them...every 4-5 feet if you like. Then look at the chart when you want to know what's what.
Do you want it your way or the right way?
Old 09-16-2012, 08:11 PM   #9
deverson's Avatar
Rewards Points: 77
Take a small piece of romex jacket, write on it and slip over the wire. Cheap and big enough to get on most info.
deverson is offline   Reply With Quote
The Following User Says Thank You to deverson For This Useful Post:
Missouri Bound (09-16-2012)
Old 09-16-2012, 11:34 PM   #10
no sir, that ain't gonna work -- cause there are areas that 6 or more cables are tight together (one in-between joists slot near the panel) and then also numerous holes in joists that have 2-3 cables going through...
Old 09-16-2012, 11:35 PM   #11
huh ??
Old 09-16-2012, 11:55 PM   #12
White electrical tape works nice with a sharpie write on it then cut it off the place the cable in the middle of the tape and fold it in half making the 2 sticky sides stick together around the cable
directvman is offline   Reply With Quote
Old 09-17-2012, 01:33 AM   #13
When I worked in a data center, cable management was a huge headache and we tried various methods (labels, bundling, etc.) What worked the best was a clear and updated labels on the main patch panel and corresponding circuit numbers on wires.
I think your intention is good, but some of those tags with strings will invariably get ripped off. If writing small is an issue, I agree with what Missouri Bound said earlier about writing (circuit) numbers.
BTW, don't pack those cables too tight to make them pretty. They generate heat
allthumbsdiy is offline   Reply With Quote
Old 09-17-2012, 01:36 AM   #14
" Euro " electrician
frenchelectrican's Avatar
I have done this all the time either in USA side or France side.
Use the fine point sharpe marker that work the best if you can write that small.
Or just write the numbers on the cables and next to the stud get larger marker and write it down what they are for.
Normally outside the panel I useally don't mark it beside the number then I go inside the breaker panel and find the numbered sleeve then it will tell what it goes.
Merci,
Marc
Old 09-17-2012, 06:53 AM   #15
May I ask WHY you are looking to do this??? Is your OCD THAT bad?
Point being, this is a new project, WHEN and how often do you actually think you'll need to trace or troubleshoot these cables??
I understand if it something you really want to do, I am just curious.
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 03:41 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
