Wire Junction Code Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-29-2008, 01:45 AM   #1
wfischer's Avatar
wire junction code question
When joining 2 sets of wires with wire nuts, is it required that the connection be contained within a box or fixture?
wfischer is offline   Reply With Quote
Old 02-29-2008, 02:08 AM   #2
Sparrky
kingsmurf
roger that MUST BE IN an accessable junction box/fixture . . yes
but before you gett that splice into a box . .PLEASE twist the wires
clockwise . .TIGHTLY . . .take your cutters and square it off at about 1/2 inch . . .THEN . . .put a wire nut on that splice and CRANK IT DOWN tight!
if you are doing some home wiring . . .PLEASE go to the store and get a good residential wiring book and do a wee bit of reading . . .you AND your Family will be very happy you did
Kingsmurf is offline   Reply With Quote
Old 02-29-2008, 02:22 AM   #3
" Euro " electrician
frenchelectrican's Avatar
Oui, it have to be in the junction box and you can not bury it in the wall.
Merci, Marc
Old 02-29-2008, 09:52 AM   #4
wfischer's Avatar
I know how to do the splicing, and I successfully completed a residential wiring class many years ago. I was just curious if splice-in-a-box was a "code requirement" or just a "good idea". Thanks for the tips, though.
Making sure the junction box is accessible though... that may put a damper on my plans.
Old 02-29-2008, 09:56 AM   #5
Rewards Points: 150
You should consider repeating that class.
JGarth is offline   Reply With Quote
Old 02-29-2008, 11:36 AM   #6
Sparrky
Kingsmurf
Apologies . .I never mean to offend anyones experience . .but that said it is an DIY ELECTRICAL forum . . . .generally a suicidal adventure for untrained home owners . . .
we can never know anyones level of experience lest thats stated aforehand . .right?
be thick skinned. . its the ether
Kingsmurf
Old 02-29-2008, 01:37 PM   #7
Rewards Points: 150
Kingsmurf-
you are correct, and please keep the tips coming. I would rather read what I already know rather than not read what I don't know......
steve1234 is offline   Reply With Quote
Old 02-29-2008, 08:36 PM   #8
wfischer's Avatar
Kingsmurf - No offense was taken, and I agree with steve!
Old 02-29-2008, 09:03 PM   #9
Res Ipsa Loquitur
The objective is to protect the splice. For convenience in an existing space it might be necessary to install an old work box, fish the lines to there and make the splice, finishing it off with a simple blank cover.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 03-01-2008, 10:21 AM   #10
wfischer's Avatar
For this project I'd be able to use a new work box. My problem at this point is that I'm trying to go as cheap as possible. I know boxes are cheap... but I already got the light fixture, the switch, and the romex for free
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 10:30 AM
3 wire to 4 wire question macmouse Electrical 24 05-01-2008 06:34 AM
Conduit, above ground, code question davewest Electrical 6 02-27-2008 04:55 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
code question JustJoe Building & Construction 3 01-27-2007 10:06 AM
