Old 11-03-2007, 12:13 AM   #1
4th Year Apprentice
Wire Guage Sizes
One mistake i see alot of DIY's making is say:
#10 feeding to runs of #12
a simple run for you all:
"WHAT IS FED... IS WHAT CONTINUES / NO CHANGING OF THE WIRE GUAGE"
so if you feed a #10 for 2 seperate 15Amp circuits.... NO WAY, you need 2 DEDICATED #14 circuits.
If you have any questions just ask
SwiftyMcV is offline   Reply With Quote
Old 11-03-2007, 12:16 AM   #2
jproffer's Avatar
Wire Guage Sizes
There's nothing in any code I've ever seen that says you can't downsize your conductors. It DOES, however, say you have to size you OPD to the smallest conductor you have in the circuit.
It's not a bad idea to follow suit all the way through, but it's not code required.
jproffer is offline   Reply With Quote
Old 11-03-2007, 12:20 AM   #3
4th Year Apprentice
Wire Guage Sizes
True but it makes it ALOT easier for the next DIY.... if he sees a #12 on a 15 amp circuit he may assume its a 20 AMp circuit.
Old 11-03-2007, 12:25 AM   #4
jproffer's Avatar
Wire Guage Sizes
Until he goes and looks at the breaker which he should have turned off before he started messing with it.
Old 11-03-2007, 08:04 AM   #5
Electrician philosopher
Wire Guage Sizes
I think Swifty has a point. (nothing to do with the code, but a point nonetheless)
Oftentimes in commercial and Industrial circuits are spec'd to be as large as #4 CU for a 20A branch circuit. This is for Voltage Drop. Except for RARE instances VD is not an issue for homeowners. I've never felt the need to switch conductor sizes in a house.
Andy in ATL is offline   Reply With Quote
Old 11-03-2007, 09:41 AM   #6
jproffer's Avatar
Wire Guage Sizes
I never have either, just pointing out to those that come behind us that, albeit a good idea, it's not required.
Old 11-03-2007, 06:01 PM   #7
" Euro " electrician
frenchelectrican's Avatar
Wire Guage Sizes
Majorty of the Resdentail area i useally not really worry about the VD because majorty of the runs are about 100 feet or less [ 30 metres or less ]
but other hand in commercal/ industrial location it will be diffrent ballpark of game you have to deal with this. this will get pretty common that why i useally automatically expect the wire size useally bump up a size or two. due very long run esepcally this is true with luminaire circuits. [ parking lot is worst ]
that why i useally dont advise not too much in resdentail area but there are few spots have to watch out is spa circuit's and few other but each case are diffrent.
Merci, Marc
Stove Top wire capt2 Electrical 8 10-05-2007 02:41 PM
Wire sizes based on actual connected load BigJimmy Electrical 7 08-21-2007 09:30 PM
A case of different wire sizes.... BigJimmy Electrical 3 08-21-2007 04:58 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 10:58 AM
