-   -   Wire Guage Sizes (http://www.diychatroom.com/f18/wire-guage-sizes-12989/)
SwiftyMcV 11-03-2007 12:13 AM
Wire Guage Sizes
One mistake i see alot of DIY's making is say:
#10 feeding to runs of #12
a simple run for you all:
"WHAT IS FED... IS WHAT CONTINUES / NO CHANGING OF THE WIRE GUAGE"
so if you feed a #10 for 2 seperate 15Amp circuits.... NO WAY, you need 2 DEDICATED #14 circuits.
If you have any questions just ask
jproffer 11-03-2007 12:16 AM
There's nothing in any code I've ever seen that says you can't downsize your conductors. It DOES, however, say you have to size you OPD to the smallest conductor you have in the circuit.
It's not a bad idea to follow suit all the way through, but it's not code required.
SwiftyMcV 11-03-2007 12:20 AM
True but it makes it ALOT easier for the next DIY.... if he sees a #12 on a 15 amp circuit he may assume its a 20 AMp circuit.
jproffer 11-03-2007 12:25 AM
Until he goes and looks at the breaker which he should have turned off before he started messing with it.:thumbsup:
Andy in ATL 11-03-2007 08:04 AM
I think Swifty has a point. (nothing to do with the code, but a point nonetheless)
Oftentimes in commercial and Industrial circuits are spec'd to be as large as #4 CU for a 20A branch circuit. This is for Voltage Drop. Except for RARE instances VD is not an issue for homeowners. I've never felt the need to switch conductor sizes in a house.
jproffer 11-03-2007 09:41 AM
I never have either, just pointing out to those that come behind us that, albeit a good idea, it's not required.
frenchelectrican 11-03-2007 06:01 PM
Majorty of the Resdentail area i useally not really worry about the VD because majorty of the runs are about 100 feet or less [ 30 metres or less ]
but other hand in commercal/ industrial location it will be diffrent ballpark of game you have to deal with this. this will get pretty common that why i useally automatically expect the wire size useally bump up a size or two. due very long run esepcally this is true with luminaire circuits. [ parking lot is worst ]
that why i useally dont advise not too much in resdentail area but there are few spots have to watch out is spa circuit's and few other but each case are diffrent.
Merci, Marc
