Wire Gauge Help - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 11:28 AM   #1
wire gauge help
What gauge wire do you need for 150 Amps and 200 Amps?
I am just making a chart thanks.
biferi is offline   Reply With Quote
Old 03-07-2012, 12:31 PM   #2
Too Short? Cut it Again!
There is a sacred book Sparkies use. I think they charted and worked out the new round wheel you have in mind.
I hire but do not speak for them. I have heard them speak of amperage and voltage in the same sentence but cannot phathom how to answer your question.
Physics people scare me more. They all wear rubber shoes.
Just to help you. Rock out Dude. 200 amps worth of electricity could run a rock concert. If three phase voltage were on stage.
Answer to your question? 24g, copper or aluminum stranded.
Old 03-07-2012, 12:59 PM   #3
According to this link
http://home.earthlink.net/~jimlux/hv/fuses.htm
Practical example> 16 gauge copper wire: Tmelt = 1083, Area = 2581 circ mil, Time = 5 sec,diam = .0524 inches
Using Preece equation:
= 10244*.0524^1.5 = 123 Amps
Using Onderdonk equation:
Ifuse = 2581 * SQRT( LOG((1083-25)/(234-25)+1)/(5*33))
177.7560411
176.9444452
= 178 Amps
#16 AWG will last 5 seconds carrying 178A in free air over some range of currents and times, so you probably want to go heavier than this.
This link
http://www.google.com/search?client=...UTF-8&oe=UTF-8
will help you narrow down your options some.
Old 03-07-2012, 01:03 PM   #4
joed's Avatar
Rewards Points: 11,610
Post your location. It differs between Canada and the US per codes. Can also differ depending on the use. Service entrance can different than sub panel feed.
The Following 2 Users Say Thank You to joed For This Useful Post:
frenchelectrican (03-07-2012), Speedy Petey (03-07-2012)
Old 03-07-2012, 01:15 PM   #5
Rewards Points: 1,092
I believe this is accurate. #4 copper ( or #2 Alum.) for 100 amp; 2/0 copper (or 4/0 Alum.) for 200 amp. Make sure aluminum is legal in your area.
The Following User Says Thank You to jklingel For This Useful Post:
trekketoo (03-13-2012)
Old 03-07-2012, 02:26 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
As Joe said, this is for residential services ONLY.
Speedy Petey is online now   Reply With Quote
Old 03-07-2012, 02:27 PM   #7
An old Tradesmen
Rewards Points: 6,142
Moved to the Electrical forum.
There is no one wire size for X amps. As the length and how it is to be installed will play a big roll in sizing.
The Following User Says Thank You to beenthere For This Useful Post:
user1007 (03-07-2012)
Old 03-07-2012, 02:41 PM   #8
Length being important is a good point: I should have included XX size for YY feet.
Old 03-07-2012, 02:52 PM   #9
Missouri Bound's Avatar
This can help..look here.
Wire ampacity chart
Do you want it your way or the right way?
Old 03-07-2012, 02:58 PM   #10
Julius793's Avatar
Yes there is, 4/0 al is able to hold 200a. Now if you decide to do a 1000' run you'll have to upsize, however it's still able to carry 200a.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 03-07-2012, 03:24 PM   #11
An old Tradesmen
You didn't take your masters test yet, did you.
The Following 3 Users Say Thank You to beenthere For This Useful Post:
frenchelectrican (03-07-2012), Speedy Petey (03-07-2012), user1007 (03-07-2012)
Old 03-07-2012, 05:27 PM   #12
xxxxxxxxxxxxx
two screwups are better than one
Old 03-07-2012, 05:59 PM   #13
From
http://en.wikipedia.org/wiki/American_wire_gauge
copper, 90C,
a simple formula that gets you very close to these values is
CM = 16.64 x amps^1.7 + 1631
E.g.,
amps = 25
CM= 3959
amps = 95
CM= 38306
amps = 260
CM= 212122
Old 03-07-2012, 11:56 PM   #14
Originally Posted by Yoyizit View Post
xxxxxxxxxxxxx
Seldom with electricity. I ask again. Amps married to which voltage. The poor boy is just trying to make a chart which I think already exists. Help him out with wire gauge at 200 amps at 24v just for example to turn a landscape light on. How many amps at 12v, and at what wire size does it take to start the engine of a car?
Old 03-08-2012, 12:32 AM   #15
JOATMON
ddawg16's Avatar
Rewards Points: 850
When it comes to amps....voltage is not an issue....100 amps at 12v is no different than 100 amps at 1000v.......it is still 100amps.....now, if your talking watts....big difference....
10 Gauge wire with 30amp circuit and Baseboard Heat? RocketManZ Electrical 4 12-17-2011 01:19 PM
What size ground wire should I use for 8 gauge power dxmullin Electrical 1 07-06-2011 03:57 PM
Hot Water Heater Wire Gauge bphilip Electrical 16 09-18-2010 08:23 PM
20A Breaker, 14 gauge wire? joside Electrical 12 08-25-2010 10:41 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
