Wire Gauge For Electric Water Heater? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 07:51 PM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Wire gauge for electric water heater?
Helped a buddy replace WH today. WH was in garage and made for an easy job. When I disconnected the electric feed to the WH I noted it was #12 THHN in Flexible Metal Conduit from a JB above the WH. Opened the JB and the THHN was connected to 10-2 NM coming out of the wall (Circuit breaker was a 2 pole, 30 amp).
I was not comfortable leaving it as it was so I went to a supply house and bought some #10 THHN and pulled that into the FMC.
Is there any way the #12 was code compliant? WH (old and new) has 4500 watt elements. Could the #12 in the FMC be considered a fixture whip?
Coastal South Carolina
Old 05-14-2013, 08:04 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,970
You were right. #12 is not compliant there.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Question on return line for water heater daluu Plumbing 10 09-09-2012 10:38 PM
Water Heater Constantly Failing/Replaced DroidGuard12 HVAC 6 04-11-2012 03:41 PM
water heater relief valve dripping (with gauge readings) ziguan Plumbing 10 01-28-2011 10:12 AM
Hot Water Heater Wire Gauge bphilip Electrical 16 09-18-2010 07:23 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
