Wire Gauge For Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 08:30 AM   #1
Wire Gauge for Dryer
Just looking to verify the wire gauge for an electric dryer. 30 amp circuit, 95 feet from plug to circuit breaker.
Going to run 8-3 with ground.
Yes?
tjl5709 is offline   Reply With Quote
Old 06-18-2012, 08:37 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
10-3 CU and wouldn't think twice.
The Following User Says Thank You to k_buz For This Useful Post:
tjl5709 (06-18-2012)
Old 06-18-2012, 09:36 AM   #3
Rewards Points: 1,452
For the dryer, which draws predomininantly 240 volts on a 30 amp circuit, it could be 150' away before you need to upsize to 8 gauge wire to combat voltage drop problems.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 06-18-2012, 12:15 PM   #4
Rewards Points: 82
Yes?
Why not? You can use #10, but if you already have #8, go for it.
10 Gauge wire with 30amp circuit and Baseboard Heat? RocketManZ Electrical 4 12-17-2011 01:19 PM
What size ground wire should I use for 8 gauge power dxmullin Electrical 1 07-06-2011 03:57 PM
Hot Water Heater Wire Gauge bphilip Electrical 16 09-18-2010 08:23 PM
20A Breaker, 14 gauge wire? joside Electrical 12 08-25-2010 10:41 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
