Wire Gauge And Circuit Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 09:46 PM   #1
Wire Gauge and Circuit Breakers
I'm finishing my basement myself. I plan to run 14/2 or 14/3 wire for lights and 14/2 for receptacles.
Does it matter if I run 14 or 12 gauge wire to a 15 amp circuit breaker or run 14 or 12 gauge wire to a 20 amp circuit breaker?
Basically are 20 amp single pole circuit breakers and 15 amp single pole circuit breakers interchangeable except I guess for the amount of total capacity they can handle?
Thank you for your responses.
Red Truck is offline   Reply With Quote
Old 01-19-2012, 09:50 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Use 12g wire for the 20a breakers and 14g wire for the 15a breakers.
What all are you having for rooms in the basement ?
plummen is offline   Reply With Quote
Old 01-19-2012, 09:51 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
#14 wire can only be installed on a 15 amp circuit.
Don't bother running #12 and install a 15 amp breaker.
The Following User Says Thank You to jbfan For This Useful Post:
plummen (01-19-2012)
Old 01-19-2012, 09:51 PM   #4
jproffer's Avatar
Rewards Points: 706
20A circuit must have at least 12g conductors
15A circuit must have at least 14g conductors
The max breaker size is determined by the smallest conductor on the circuit.
jproffer is online now   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
Old 01-19-2012, 10:08 PM   #5
Just a Rec room and Office. I am planning on running a separate circuit for the TV and a separate circuit for the computer. There will also be a refrigerator down there (probably another circuit) Other than that nothing else major that will be using electricity.
Old 01-19-2012, 10:18 PM   #6
How many 6 inch recessed lights can I run on the 15 amp breaker?
Old 01-19-2012, 10:25 PM   #7
jbfan's Avatar
Rewards Points: 254
A 15 amp circuits gives you 1800 watts of power.
You figure the max lighting allowed based on the max lamp the fixture will take.
Old 01-20-2012, 01:22 AM   #8
" Euro " electrician
frenchelectrican's Avatar
Red Truck.,
I am not sure if you are aware with most states will required a AFCI protection due this is a finshed basement room so that will count toward to the AFCI requirment.
Merci,
Marc
Old 01-20-2012, 10:00 AM   #9
Originally Posted by frenchelectrican View Post
Red Truck.,
Merci,
Marc
Thank you Marc! I will look into it. I didn't see any AFCI breakers in my service panel which is all new as of 2008. I guess it's better to be safe then sorry. I assume these breakers are much more costly.
Old 01-20-2012, 03:19 PM   #10
Yes and you will likely get nuisance trips. To troubleshoot these things your electrician will probably need to rent an Intelli-arc troubleshooting device made by Siemens, or some similar device.
IMHO these AFCI devices give you the least additional safety for the most additional money. Either the NEC has a strong lobby or nobody ever questions their cost/benefit decisions or both.
Search the Web for all the patents on these things - each new patent strives to overcome the shortcomings of the previous designs.
Old 01-20-2012, 03:32 PM   #11
plummen's Avatar
If its just an office i personally wouldnt worry about an afci,unless you use it as a bedroom
Old 01-20-2012, 03:45 PM   #12
Rewards Points: 150
Question:
Does NEC dictate a strict number of fixtures per circuit like Canada does?
Or, as jbfan writes, is it just calcing the loads per max wattage of each fixture?
psilva8 is offline   Reply With Quote
Old 01-20-2012, 03:55 PM   #13
Licensed electrician
Rewards Points: 1,290
The NEC only has limits on non-residential installs as far as number of receptacles on a circuit.
Old 01-20-2012, 04:00 PM   #14
plummen's Avatar
I normally figure 1 circuit for each bedroom,makes life much easier if you ever need to work on something down the road.
For your office you might want to figure a couple extra plugs on a seperate 20a circuit if youre running a lot of big stuff.
The living room might also be a good idea to split up on a couple 15a circuits if you have lots of stuff to plug in
Old 01-20-2012, 04:06 PM   #15
So you feel it is OK to pick and choose which parts of the code to comply with?
14 gauge wire 20 amp circuit DIYGST Electrical 24 03-05-2013 05:15 PM
10 Gauge wire with 30amp circuit and Baseboard Heat? RocketManZ Electrical 4 12-17-2011 01:19 PM
12 and 14 gauge wire on one circuit whatrymes Electrical 4 04-17-2011 10:32 AM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
mixed gauge wire on 15 amp circuit GretaDIY Electrical 4 07-03-2010 04:20 PM
