Old 10-19-2012, 10:31 PM   #1
wire gauge
Have an existing light fixture junction box. Want to add a gfi receptacle about 10' from the box. The existing wire in the box is 14/2. Can 12/2 wire be used from the box to the gfi receptacle? Thank you.
gt1935 is offline   Reply With Quote
Old 10-19-2012, 10:41 PM   #2
Missouri Bound's Avatar
wire gauge
It can, but why put yourself through the pita of wiring anything with 12ga if you don't have to. I"m guessing you have some laying around. What it could do however if anyone opened up that GFCI and saw the 12ga they could assume that the circuit is a 20 amp. Not a big concern, just sayin'.....
Do you want it your way or the right way?
10 Gauge wire with 30amp circuit and Baseboard Heat? RocketManZ Electrical 4 12-17-2011 01:19 PM
What size ground wire should I use for 8 gauge power dxmullin Electrical 1 07-06-2011 03:57 PM
Hot Water Heater Wire Gauge bphilip Electrical 16 09-18-2010 08:23 PM
20A Breaker, 14 gauge wire? joside Electrical 12 08-25-2010 10:41 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
