Wire Gauge - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 08:48 AM   #1
Wire Gauge
I'm installing a 4000W in-wall electric blow heater. It will only draw 16.7 amps. My question is, can I use 12/2 romex for this circuit or do I have to go with 10/2.
Zanayed is offline   Reply With Quote
Old 04-19-2011, 10:46 AM   #2
joed's Avatar
Rewards Points: 13,696
20 amp circuit and 12/2 should be fine.
Old 04-19-2011, 05:43 PM   #3
Scared Electrician
Saturday Cowboy's Avatar
actually NO remember the 125% rule with heaters. 17a x 125 = 21.25a too much for a 20a circuit. The next size is 25a but most people skip to the next size 30a and you will need #10 wire
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-20-2011, 04:33 PM   #4
Thanks for the info....I did some research and found that although a 20a circuit would probably work, it is not up to NEC code since it is a 4000W heater. I will go with a 30a circuit and use the 10AWG wire.
Hot Water Heater Wire Gauge bphilip Electrical 16 09-18-2010 07:23 PM
20A Breaker, 14 gauge wire? joside Electrical 12 08-25-2010 09:41 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
Should a dryer be 10 gauge wire & range 8/3? twilightcall Electrical 7 07-03-2008 06:29 AM
Gauge Wire and Breaker Discrepancy broken_scout Electrical 26 12-22-2007 10:07 PM
