Wire For Gas Fireplace - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2016, 02:50 PM   #1
Rewards Points: 40
Wire for gas fireplace
1. What kind of wire / sheathing should be used to get power to a gas fireplace?
2. There is a metal backing inside the existing fireplace and the gas fitter will put a hole through the metal to get the gas line through? Does anyone know if code permits electrical wire to be put next to the gas line through this hole or using the ash trap door the way to go to get power to the fireplace?
AidaCarrell is offline   Reply With Quote
Old 05-30-2016, 03:08 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Re: Wire for gas fireplace
Gas fireplaces typically do not use line voltage power. A fan will though. So telling what wire is impossible unless we know what the wire is for.
All the ones I have done have had small junction boxes in the compartment where the valve and other parts are. You will likely need a wall switch as well.
Old 05-30-2016, 03:47 PM   #3
Rewards Points: 40
The power is for the fan. Needs 1A.
Old 05-30-2016, 04:02 PM   #4
Then either a 15 or 20A circuit will work. Typically this is fed from an existing local circuit. Just match the wire size.
Old 05-30-2016, 04:58 PM   #5
Rewards Points: 40
I don't think I should be using regular Romex nylon wire through the ash pit as the wire can get damaged.
Old 05-30-2016, 05:07 PM   #6
Licensed electrician
Rewards Points: 1,612
Why would a gas fireplace have an ash pit?
How is a cable under the fireplace going to get damaged?
Speedy Petey (05-30-2016)
Old 05-30-2016, 05:40 PM   #7
Rewards Points: 40
It's an old fashion fireplace that is going to re-purposed to hold a gas fire.
The fireplace ash pit is made out of brick or blocks. As wire is pulled up, it may scratch against the bricks and get damaged.
Would it not be better to put some sort of sheathing around the wire like BX?
Old 05-30-2016, 08:54 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 1,686
Interesting. I've never seen or heard of an approved conversion of a wood fireplace to gas except for self-contained self-enclosed insert units. If it's not a self-contained insert unit, how would it draught (exhaust) properly without potentially killing everyone in the house? If it's an insert, then the above comments regarding fan wiring in the valve-piping compartment stand.
lenaitch is offline   Reply With Quote
Old 05-31-2016, 10:34 AM   #9
Rewards Points: 40
The gas fire is a self-contained unit. The old fireplace is just a place to put it.
Let me re-state the question. What wire sheathing should be used when wire is exposed or pulled through places where it can get damaged?
Dual switch and two leads: 30V of power 'bleeds' from one wire into the other SuperFun Electrical 3 03-21-2016 04:52 PM
Use red and black wire as 110 in Canada mattm Electrical 10 11-26-2012 07:40 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
