Wire Connectors - Electrical - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 07:13 PM   #1
Wire connectors
I am planning on wiring our new sunroom myself. The local wiring inspector has told me he wants me to use Buchanan crimp type wiring connectors - green for the grounding connections. I have not been able to find them on the web, the only crimp type I can find are bare. Am I blind? His office also told my my application had to be accompanied by a letter from my insurance company. When I called our insurance company, they had never received such a request and didn't know what the letter was supposed to say, but they did agree that they are not qualified to judge whether I am competent to do the work. Does anybody know where I can purchase green crimp type wire connectors?
Larryg is offline   Reply With Quote
Old 07-05-2010, 07:21 PM   #2
google "Buchanan crimp" and you will find lots of sources. Keep in mind it uses a relatively expensive crimp tool.
ttech is offline   Reply With Quote
Old 07-05-2010, 07:36 PM   #3
the Musigician
DangerMouse's Avatar
I don't see why you cannot use green wire-nuts and pigtail the ground wire to the fixture.
My electrical inspector is a real stickler, but he isn't making me crimp....
DM
Old 07-05-2010, 07:40 PM   #4
the Musigician
If you, as a homeowner are allowed in your county to do the work, then you are doing your job just by being here and asking questions to be sure it's done correctly, HIS job is to make sure it is too. If he INSISTS on you using crimp, ask him where to purchase them, if he does not know, ask if code prohibits green wirenuts....
DM
Old 07-05-2010, 08:33 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Not sure Buchanan crimps come in green. Maybe if you let them oxidize for awhile it will be green enough for him.
Old 07-05-2010, 08:52 PM   #6
Where are you located ?
Old 07-05-2010, 09:44 PM   #7
Rewards Points: 1,910
Your inspector and his office are obviously anti-DIY and making up fictional requirements. Ask the office for clarification on the letter. All your insurance company can do is give you a letter that you have insurance with them. Tell the inspector your going to use the same wirenuts that most electricians in your area are using.
Old 07-06-2010, 09:45 AM   #8
Rewards Points: 160
I agree with jogr. Crimp connectors are not an NEC requirement. But it is better to keep your inspector happy.
Old 07-06-2010, 10:10 AM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
They do NOT have to be crimped with the special 4-way crimper. See the image below where it says "Alternate tools".
Ideal also makes the same crimps, only in steel, and can be crimped with ANY regular crimper. Linemans with a built-in crimper work as well as this tool:
Old 07-06-2010, 10:14 AM   #10
Oh, and I also agree with this:
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 08:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
Push in connectors vs. wire nuts sanny651 Electrical 5 02-17-2010 08:26 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
