Wire Connector For Grounds - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2010, 08:40 PM   #1
Wire connector for grounds
I have a 2-gang box with 2 3-way switches. The left switch has incoming power from another 3-way and out to recessed lights. The right switch has incoming power from nearby outlet, outgoing power to light at bottom of stairs and another to 3-way at top of stairs. My question is normally all the grounds in the box would be connected together but I count 7 when I include the pigtails for the grounds for each switch. No way these can be connected with 1 wire connector, correct?, so is connecting the grounds for each switch OK using 2 separate wire connectors?
8roty is offline   Reply With Quote
Old 01-04-2010, 08:56 PM   #2
Electrician
Rewards Points: 802
You should be able to get 7 wires under one marrette, you will have to get the really big ones, I always call them big blues.
The challenge for you may be makeing the joint with seven wires, not always the easiest thing for a DIY.
If you have two split them up into two sets and run a bare wire between them.
darren is offline   Reply With Quote
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
Red wire is HOT genner Electrical 15 02-22-2009 08:14 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
