Wire Connection - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2013, 12:14 AM   #1
Rewards Points: 528
wire connection
Has anyone ever seen a #12 coming in to main panel box and both neutral an black coming in to hot side ,breakers are seperated by other ones, is on 2 different tandom circuits 20 amps. .I know white should be neutral but unsure on this set up.
Any info is appreciated.
In pic the 2 red 20 amps breakers at left bottom are the ones spoken on
.they both are on bottom of each tandom..many pics show them in breaker, one shows them out.wire connection-imag0549-2.jpg
hidden1 is offline   Reply With Quote
Old 05-15-2013, 12:38 AM   #2
Rewards Points: 512
I can't tell: are both thee white and black wire coming from the same cable (where they enter the box)?
Is this a Cutler Hammer Panel?
Installation is the Reverse of Removal.
Old 05-15-2013, 04:20 AM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,316
Hidden.... I asume they are on different phase and 240. Can you confirm with a multi-meter.?
Don't know if you can trace them, but are they in the same cable/romex.?
Are the circurs labeled in any manner.?
Do you have any electric baseboard heat in the house?
(Very tentative.... just wondering/guessing if someone highjacked/used the 12/2 to install baseboard 240 heater.)
MTN REMODEL LLC is offline   Reply With Quote
Old 05-15-2013, 09:35 AM   #4
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
that is a twin breaker ... so only 1 phase .. but defenatley needs to be traced as somwone said to find out what wire it is coming in and its purpose ... it may be a splice/jumper not maked ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-15-2013, 10:03 AM   #5
Philly.... Just curious... I'm a GC and only work very limited electrical (mine, 2 kids basically)....
but are there not some boards that take a tandem/twin off both phases..... could swear I've seen the breakers with handle ties on them in the parts sections .... (for MWBC or 240)...maybe not... I'm older and that happens.
Peter
Old 05-15-2013, 10:30 AM   #6
Rewards Points: 516
The Following User Says Thank You to Philly Master For This Useful Post:
MTN REMODEL LLC (05-15-2013)
Old 05-15-2013, 10:33 AM   #7
Rewards Points: 330
zinsco,ge,grouse-hinds use the thin tandem looking 240 breakers.what you have philly is called a quad tandem.sq-d amd others use those.i think what mtn remodel is refering to is just a tandem type/style.
oleguy74 is offline   Reply With Quote
The Following User Says Thank You to oleguy74 For This Useful Post:
Old 05-15-2013, 10:38 AM   #8
Rewards Points: 516
show me a good picture ....
Old 05-15-2013, 10:49 AM   #9
Rewards Points: 528
I will trace them but both black and white wire are on same line coming in to box.basic 12/2 . One goes to the top tandom . And the other to a different tandom 2 spots below it and are not joined .2 seperate 20 on each one.they each have another seperate hot ,not joined ,on other circuit in tandom breaker,can individually turn off an on all 4 breakers. No baseboard heat and is crouse hinds box,uses Siemens breakers and at bottom had older style ,now removed.wire connection-imag0497.jpg
Old 05-15-2013, 11:34 AM   #10
Licensed electrician
Rewards Points: 1,752
Sounds like someone tried to make a 240 work off of two different breakers so both legs were used. This could leave one leg hot while the other was turned off. A 2 pole breaker should have been used.
Old 05-15-2013, 11:46 AM   #11
Rewards Points: 512
What? It looks to me like the Black is on one/half of the tandem, while the white is on the other half, making them be on the same phase!?
And I'm having a hard time understanding what you mean in the rest of the statement.
Old 05-15-2013, 11:52 AM   #12
Rewards Points: 512
definitely, they are on the same tandem
Old 05-15-2013, 12:46 PM   #13
Rewards Points: 330
post #9 shows a grouse hinds.
Old 05-15-2013, 12:56 PM   #14
Rewards Points: 330
breakers
ge type 240.is this what you want?
Philly Master (05-15-2013)
Old 05-15-2013, 01:53 PM   #15
Rewards Points: 516
Can I see the bottom ??
ROMEX 14-2 wire from Canada Vs. ROMEX 14-2 wire from the U.S. Dazzlin Electrical 18 11-02-2016 03:15 PM
How to rewire outlet controlled by light switch? BuckyGunts Electrical 30 04-20-2012 02:18 PM
How increase the length of wire to line connection wdrrob Electrical 9 08-02-2011 04:30 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
