Wire Confused Which Is Which - Electrical - DIY Chatroom Home Improvement Forum
Old 01-29-2009, 01:59 PM   #1
Wire confused which is which
Hi there,
A while ago, I removed an ugly old chandelier that came with my apartment and wired a nice one. I am now moving and need to put back the old one and the old one has a "see through" golden colour cord with copper looking wire coming out of it. I can't figure out which is the white and which is the black, it seem that one side has little ribs on the cable and the other is smooth. I did so much research and can't figure it out. Any help would be greatly appreciated.
Caro
Caro is offline   Reply With Quote
Old 01-29-2009, 02:22 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Ribbed neutral(white), smooth hot(smooth).<<<<oops, meant black
wirenut1110 is offline   Reply With Quote
Old 01-29-2009, 02:56 PM   #3
Thanks a bunch, it worked perfectly!
Old 01-30-2009, 10:31 AM   #4
Rewards Points: 160
Are you sure. It would work perfectly even if the wiring is wrong. The neutral must go to the threaded shells of the sockets and the black "hot" must go to the tab down in the middle of the socket. It will work either way, but if wired backwards the shell will be hot and that is not good.
Old 01-30-2009, 12:30 PM   #5
Hi, well it seem to work fine, I had a modern light that I instaled myself there about 6 years ago, since it is a new light, it has a black and a white cable, so I wired the white with white and black and black (ground with ground). It's been like that for about 6 or 7 years and it worked just fine. Now I am moving and I had to put back the old one, so I just needed to know which was which on the old light...
I thought if you wire backward it would spark or short circuit, I did it once and I had a spark with a little fire, nothing big but enough to scare the ... out of me...
Old 01-30-2009, 12:40 PM   #6
DIYer
No, with AC power it's often difficult to tell when someone reversed the wires, since stuff mostly still works. But it can create latent hazards for electrical shock down the line.
Gigs is offline   Reply With Quote
Old 01-30-2009, 07:28 PM   #7
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Some AC devices are sensitive to reverse polarity and will not engage if wired wrong, i.e. some Nautral gas furnaces.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
Trying to wire my bathroom... confused... Alan Electrical 3 11-23-2008 04:44 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
