Wire & Conduit Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 01:47 PM   #1
wire & conduit installation
My town utilizes NEC 2008. I'm in the process of installing a inter-lock kit for a portable 6500W generator (240V, 30 amp). The portable generator will be outside under overhead cover, and the main house distribution panel is located indoors (garage unfinished space).The power inlet box will be mounted outside along exteroir wall feeding the main panel via an interlock kit located inside. The wire size will will be a number 10 with 4 (black, red, green, white) wires. The questions I have are as follows:
*Does the wire have to be solid or can it be stranded?
*Since the insulated wire will be routed through the exterior garage wall (mason) thru unfinished space along the wall, I'm sure it will have to be in condiut or some type of protection. What is required, metal conduit, PVC conduit, flexible metal shielded cable (BX), or PVC flexible (liquid tight) cable?
*Does the ground wire need to be insulated?
thank you
rcassidy is offline   Reply With Quote
Old 01-03-2012, 06:42 PM   #2
Licensed electrician
Rewards Points: 1,474
Cables do not have to be in conduit unless it is to protect them from physical damage. Individual conductors require conduit.
Solid or stranded is fine for the #10.
Old 01-03-2012, 07:26 PM   #3
jproffer's Avatar
Rewards Points: 706
....... EDITED OUT for the sake of not giving/taking mis-information or information against code.
jproffer is offline   Reply With Quote
Old 01-03-2012, 09:43 PM   #4
Missouri Bound's Avatar
rcassidy...I would run the individual wires through metallic or non-metallic conduit. It's neater and makes for room for expansion in case you decide you need a larger generator. 4- 10's stranded will suffice instead of a cable.
Feeder wire in and out of conduit quadradeuce Electrical 3 12-31-2011 05:44 PM
GE Sunsmart Digital Timer Installation dtn311 Electrical 1 08-01-2011 01:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dimmer Installation rjl24 Electrical 4 02-20-2008 07:43 PM
Bonding (bond wire) & Spa Installation on existing concrete pad crusius2 Electrical 1 11-14-2007 12:00 PM
