Wire Colors - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2009, 09:40 PM   #1
Wire colors
I need to run a third wire for a ceiling fan (currently white and black) so I can have a 2 way switch. Can I make the second hot to the fan black also, or does it need to be a different color to meet code?
howard.wheaton is offline   Reply With Quote
Old 06-22-2009, 10:55 PM   #2
Union Electrician
goose134's Avatar
Black will be fine. Another color might make it easier on the next guy, but not by much.
goose134 is offline   Reply With Quote
Old 06-23-2009, 06:12 AM   #3
You can usually identify the 3rd wire with tape(red is good) or permanent markers.
Old 06-23-2009, 10:47 AM   #4
Rewards Points: 2,350
Well, the others are right that it can be black, but how are you planning to add this wire? Unless there is conduit between the switch and light, you can't just run a single wire. In other words, if it is romex or any other type of cable, you either need to replace the cable with a 3-wire version, or scrap the project.
Old 06-23-2009, 11:30 AM   #5
This.^
A lot of old timers used to run 3-way switches this way, and a lot of shadetree electricians still do. However this is most definitely a code violation. Even if you are running conduit, if the 2-wire cable is Romex, you will still have to re-run a 3-wire cable. If any of the wires are in a separate sheathing, then they will all have to be in it.
Atroxx is offline   Reply With Quote
Old 06-23-2009, 11:41 AM   #6
Rewards Points: 126
Whats a two way switch and how did a three way get in this thread? If you want independent control of the light and fan you need 2 switches or a double switch on a single gang yoke. If you have conduit you can add the extra wire. If you have a cable you must replace it with a three conductor cable.
Please be more specific with your questions. We can help much more with the right information. InPhase summed it up pretty good. Look at his post.
Old 06-23-2009, 11:42 AM   #7
Remodeler
adpanko's Avatar
Rewards Points: 150
I agree that you basically need to rerun 14/3 the entire length between the switch and the ceiling box. You can't just run a single wire.
adpanko is offline   Reply With Quote
Old 06-24-2009, 12:04 PM   #8
I actually just took a third wire and pushed it up the conduit at the wall switch and it popped out in the ceiling fan box. That Romex stuff can't be used where I live.
Old 06-24-2009, 12:10 PM   #9
Well that answers that!
KeithM62948 is offline   Reply With Quote
Old 06-24-2009, 02:25 PM   #10
......nevermind
Old 06-24-2009, 08:08 PM   #11
Electrician
Rewards Points: 788
Wouldn't that make your day easy sometimes, i wish it was always as easy as pushing it in the box and it mircasouly shows up where you need it. I try that and it just bunches up in the wall
darren is offline   Reply With Quote
Old 06-26-2009, 10:59 AM   #12
Rewards Points: 126
Thats why I love conduit.
Old 06-26-2009, 11:01 AM   #13
Amen to that!
Old 06-28-2009, 08:39 AM   #14
Rewards Points: 1,494
You still need luck to have the new wire go up the partially occupied conduit and out where you wanted it to without kinking and bunching inside.
Old 07-01-2009, 04:48 PM   #15
Journeyman Wireman
All houses should be conduit! A lot more work for us good guys too!
jbberns is offline   Reply With Quote
Wire colors SKINNY Electrical 8 05-31-2009 10:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Wire colors to a switch jamiedolan Electrical 5 09-14-2008 02:01 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
