Wire Colors - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2009, 03:13 PM   #1
Lake Forest, CA
Wire colors
Quick question for you guys.. I am installing a spa and it has 240V 60A power requirement.. I plan on running 6ga THHN wire across the approx 100' run... To run this in the proper color combination 2 Hot (black), Neutral (white), Grnd ( green) will run me about $320 at .80 cents/ft at Home Depot.. However I can buy a single color spool of 500' for $190 which comes out to .38 cents/ft. Would it be wrong to buy a black spool and use colored tape to mark the colors at the terminating ends?
tnx..
SKINNY is offline   Reply With Quote
Old 05-30-2009, 03:18 PM   #2
300zx's Avatar
Post
You can do that but it will have to be in conduit.You might try electrical supply shop and get alot cheaper And put on GFCI Breaker
300zx is offline   Reply With Quote
Old 05-30-2009, 03:38 PM   #3
It's not code, but I've done it a time or two...
BTW, you should only need a #10 for the ground. At least buy green for the ground.
jerryh3 is offline   Reply With Quote
Old 05-30-2009, 03:47 PM   #4
Idiot Emeritus
Rewards Points: 1,492
While this would be a violation of 250.119 and 200.6, I don't know how many hundreds (maybe thousands) of times I've used all black wire and used colored tape to identify it.
Almost all of my work is inspected, and I've yet to have anyone question it.
Rob
micromind is offline   Reply With Quote
Old 05-30-2009, 09:01 PM   #5
http://www.wesbellwireandcable.com/Electricalwire.html
Check here. Prices are reasonable and you can get 6awg in black,red,white,and green
Plumbvoltage is offline   Reply With Quote
Old 05-31-2009, 04:57 AM   #6
" Euro " electrician
frenchelectrican's Avatar
With the #6 { 16mm˛} and larger you can able remarked with coloured tape however if in cable that is not a issue but for indivual conductors that can be a fineline to crossover but for myself I done that more than once and I have no issue with it and my inspectors check my work and it passed { both in Wis and Paris France locations }
To OP.,
If you order a mesure to cut conductor they will charge alot more than you can buy in spools { I know some place they will not charge extra for that } and useally get in full spool is cheaper that way and some big box store you should able get in 100 foot spools with that size.
Merci,Marc
Old 05-31-2009, 07:56 AM   #7
Rewards Points: 2,350
The wording of the Code actually doesn't allow for #6 to be re-colored, only #4 and larger. As far as code violations go, however, this is pretty low on the list.
I'd tape a piece of #6 while sitting at the table having tea with the inspector, and not think twice about it.
Old 05-31-2009, 10:51 AM   #8
Rewards Points: 82
Another guy posted he found #6 at HD for 80 cents a foot. The supply house was 30 cents. You just cut your wire budget over half. Call your local supply house on Monday. Call more than one until you find the best price.
Like the others I would mark the neutral with white tape. But I would not tape the #10 ground wire green. Bite the bullet on the #10. Use green. Most supply houses will not cut #10. You could use a green #8 instead and they will cut that. And still save money.
Old 05-31-2009, 11:16 AM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
I love this!
So true.
Yup, totally agree.
Home centers might be cheaper on 12/2 and 14/2 romex, but not much else.
THHN they are MUCH higher, as you have heard.
Speedy Petey is online now   Reply With Quote
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Wire colors to a switch jamiedolan Electrical 5 09-14-2008 03:01 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
