#1 |
DIY'er
Wire chase
HI;
In the basement, (not in the room with the drop ceiling in case you have seen photos I posted). We need to run a number of romex wires across the joists. My dad doesn't want to drill that many holes in his old joists. What are my options? Can we build some kind of chase out of wood? or just run 2x4's against the floor joists(in the other direction) and wire staple to them? Or in the best bet to run EMT and just have a box at each joist cavity that has romex? Thanks Jamie
Jamie Dolan - Neenah, WI To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Need Help Uploading Photos? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
#2 |
Wire chase
Yes you can use 2x4's or strapping and staple the wires to that no problem. All you need is a running board
#3 | |
DIY'er
Wire chaseQuote:
Thanks Jamie
#4 | |
Electrician
Wire chaseQuote:
http://www.arlcatalog.com/NM%20Cable...t%20System.htm |
| Display Modes | |
| New Stove, old wires - 2 wire vs 3 wire | DIYGST | Electrical | 22 | 03-02-2009 05:13 PM |
| hooking up dryer....bronx ny code | SURFBUG | Appliances | 6 | 10-14-2008 10:41 PM |
| Dryer Grounding??? | Traci_howdyadothat | Electrical | 7 | 05-27-2008 02:14 PM |
| Installing Fluorescents in Garage | rzrbkpk | Electrical | 26 | 04-08-2008 10:00 PM |
| Stranded wire on screw connections | BigJimmy | Electrical | 7 | 01-19-2008 03:42 PM |
