Wire Chandelier - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2010, 06:52 PM   #1
Rewards Points: 55
Wire chandelier
SEE PIC IN MY ALBUMS - I wish I knew how to paste it here.
Bought used chandelier - has a wire that looks like you cut the plug off the end of a lamp cord- one cord separated into two wires ... and a copper ground.
Wiring it to unused ceiling fan outlet box in brand new home.
Outlet box has a black, red, white and copper (ground) wire.
What to wire to what? I wired to both to black and nothing happens.
Italgrl is offline   Reply With Quote
Old 06-28-2010, 07:36 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 232
One side of the wire will have a rib, this is wired to the white wire,
The unribbed wire will wire to the black, or red, depending which switch you want to work the light, and the bare wire goes to the ground.
jbfan is online now   Reply With Quote
Old 06-28-2010, 07:45 PM   #3
Rewards Points: 55
Found a "rib"
Found a rib...but I practically went cross-eyed doing so - it's barely noticeable!
Thanks! I'll give it a try.
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 09:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 09:55 AM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 10:16 AM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
