Wire Ceiling Fan To Outlet Switch((help)) - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2009, 08:35 PM   #1
wire ceiling fan to outlet switch((help))
Hello.
Im wiring a ceiling fan to a switch by the door that also powers an outlet.
existing wires are as follows-
at swith- black wire, white wire and ground-
at outlet- black wire, white wire, white wire and ground. the outlet is cold until the switch is turned on. it looks as though the outlet has 3 sets of 14/3 going inside. black on the bottom brass screw. what wire top and bottom(not the brass)
thoughts.
thanks-
tommy281 is offline   Reply With Quote
Old 10-31-2009, 08:59 PM   #2
joed's Avatar
Rewards Points: 13,766
The only way you can tap into that switch for the fan is if you make the receptacle always on or pull a new cable to the switch.
You could tap into the receptacle for the fan.
Are you wanting the switch to control the fan?
Old 10-31-2009, 09:15 PM   #3
Thanks joed.
I ran 14/3 from the fan to the switch already. id like the switch to turn the fan and light thats on the fan on. i dont need seperate operation of the light and the fan.
im looking forthe easiest way to accomplish this
Old 10-31-2009, 10:48 PM   #4
Electrical Contractor
kbsparky's Avatar
You will have to rewire the outlet so the existing switch leg becomes a feed to the switch.
Connect all the blacks together in one wire-nut, and all the whites together in another wire-nut at the outlet box. You can use a short pigtail from each wire nut to supply power for the receptacle. The outlet will now be on at all times.
At the switch, the black wire from the outlet is now your hot feed. Connect that to your switch for the fan. The white wire from the outlet is now your neutral feed. Wire-nut that to the white wire that goes up to the fan.
Connect the remaining wire to the other switch terminal, and it will now control the fan.
-KB
Old 10-31-2009, 11:08 PM   #5
Just a guess but I would say what you have is
In which case you would disconnect the white from the switch, disconnect the white connected to the black in the outlet box. In stall a jumper from the wire nutted black in the outlet box to the other brass screw on the outlet. Wire nut the whites in the outlet box together with a pigtail to the silver screw on the outlet. Connect the fan/light black to the switch and wire nut the fan/light white to the white wire in the switch box. You should end up with this
Grounds have been left off for clarity.
hayewe farm is offline   Reply With Quote
Old 11-01-2009, 07:14 AM   #6
WOW.... thanks everyone-.
Kb i did it your way as it looked the most painless
everything worked like a charm.
hay thanks for taking the time in drawing up a graph, bravo.
ts
Old 11-01-2009, 07:53 AM   #7
kbsparky's Avatar
Originally Posted by tommy281 View Post
.... Kb i did it your way as it looked the most painless....
You're welcome
-KB
Old 11-01-2009, 09:54 AM   #8
I do have a quick question on a ceiling fan i just ordered.
http://www.homedepot.com/webapp/wcs/...-_-473786-_-52
since it is remote controled i was told that you CAN NOT operate the fan via light wall switch.
is this true????
Old 11-01-2009, 10:21 PM   #9
Rewards Points: 1,548
>>> is this true?
If turning the fan off using the wall switch and turning it back on always leaves the fan in standby-off awaiting the command from the remote control unit ... then yes.
In other words the fan does not "remember" whether it was last on or off when power is removed and restored.
Old 11-02-2009, 06:16 AM   #10
kbsparky's Avatar
Other remotes will "remember" their last setting, and go to that once power is restored.
In other words, if you have the light on, and the fan off, and then cut off the power, the remote unit should go to that same level once power is restored with the wall switch.
Your mileage may vary.
-KB
Old 11-02-2009, 09:15 AM   #11
joed's Avatar
Since you ran 14/3 to the fan you could have the fan remote always powered and not affected by the wall switch. You can use the wall switch to operate only the light if you wish.
help with wiring ceiling fan from a switch controlled outlet teamster807 Electrical 39 10-27-2011 04:09 PM
Four wire to exterior outlet? ElsReverie Electrical 5 10-19-2009 01:32 PM
Ceiling outlet box reinforcing PRedLSU Electrical 12 07-08-2009 04:12 PM
Ceiling fixture red wire????? meshell06 Electrical 4 10-19-2008 09:20 PM
Aluminum wire? Which outlet to use? papashaq Electrical 6 08-27-2007 05:36 PM
