Wire Bundling Requirements - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 12:02 PM   #1
Murdy's Avatar
Rewards Points: 37
I have heard references to wire bundles in various threads. I'm not actually sure what they are. I am running a substantial number (12) of wires (mix of 12 and 14 guage) between 2 ceiling joist to a point where they branch out to service different things. Basically, I'm following the path of how the house was wired, but it's an old house and I have no idea if it was code or what the code was when it was wired. Bascially, its about a 10 foot run where a dozen wires run in this space. Joists are 16 inches on center. Does this run afoul of any code requirements?
Murdy is offline   Reply With Quote
Old 09-10-2011, 04:41 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Typically I don’t put more than 3 cables in a hole. Normally you can stay within deration factors and pulling is easy.
Kyle
Old 09-10-2011, 04:42 PM   #3
Military Mom of 4
Snav's Avatar
Legally I'm limited to 8 in a bundle.
That's an unworkable number, though - nothing wrong with spreading it out over a short area, though - several holes.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 09-10-2011, 05:00 PM   #4
Murdy's Avatar
Rewards Points: 37
Thanks for the responses. Follow up question: if I have a bunch of wires just lying next to each other, not going through holes or anything, is that considered a bundle? Or if they are close but not actually touching? I guess basically I'm just trying to figure out what a bundle is.
Old 09-10-2011, 06:17 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Code doesn’t technically define bundling, but I believe they are referring mostly to maintaining spacing between cables for an adequate distance to allow free air to move and dissipate heat.
Should have asked before, what kind of wiring are we talking. I was assuming romex (NM). Silly me for assuming?
Kyle
Old 09-10-2011, 07:24 PM   #6
Code05's Avatar
Rewards Points: 1,104
Since a distance between cables is not specified, one micron between is good enough.
Code05 is offline   Reply With Quote
Old 09-10-2011, 07:31 PM   #7
Electrician
SD515's Avatar
Rewards Points: 504
True. We dont need no stinking spacing.
Kyle
Old 09-10-2011, 07:48 PM   #8
Code05's Avatar
Old 09-10-2011, 07:50 PM   #9
Code05's Avatar
'Splain please.
Old 09-11-2011, 07:59 AM   #10
Murdy's Avatar
Rewards Points: 37
Yes indeed, romex. Although there are a couple lines running through the same space going to different parts of the house that I didn't rewire that are that old, thick, black stuff.
Old 09-11-2011, 08:07 AM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Bottom line is, you can have up to four CABLES (size #14-#10) in a bored hole before ANY derating needs to be considered.
I can lay out the codes for you but I don't feel like it right now. You'll have to trust me.
Many places don't even consider cables running through hole "bundled".
Old 09-11-2011, 08:11 AM   #12
Code05's Avatar
You are just fishing wires in a ceiling cavity, right?
Old 09-11-2011, 11:06 AM   #13
Military Mom of 4
Snav's Avatar
Originally Posted by Code05 View Post
'Splain please.
Hrmph - sorry. Wrong forum - that was business stuff. Puzzled as to why that posted instead of the post I typed. . . glitch I guess.
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 08:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 12:51 PM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 08:20 AM
wire requirements for 15 amp 205 volts fixrite Electrical 17 10-07-2010 07:59 PM
