Old 02-16-2009, 11:34 PM   #1
wire & breaker size
Does a circuit with 15amp recepticles require a 15 amp or 20 amp breaker? Do you have to use #14 wire for 15 amp recepticles or can you use #12?
rcassidy is offline   Reply With Quote
Old 02-16-2009, 11:37 PM   #2
wire & breaker size
As long as you use a duplex outlet you can put 15A receptacles on a 20A breaker which requires 12ga wire. You can use 12ga wire on a 15A circuit if you wanted to but you can't put 14ga wire on a 20A circuit.
Plumbvoltage is offline   Reply With Quote
Old 02-16-2009, 11:40 PM   #3
Xtreme DIY'r
wire & breaker size
I use #12 if there is any chance I may want to upgrade the circuit to a 20a breaker down the road
Old 02-16-2009, 11:48 PM   #4
wire & breaker size
OK, thanks...
Old 02-17-2009, 06:39 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
wire & breaker size
Or you could just use #12 on a 20A breaker right off the bat.
rcassidy, just remember, you CAN use 15A receptacles on a 20A circuit in the US as Plumb stated.
Old 02-17-2009, 02:49 PM   #6
wire & breaker size
Awesome, thanks, thats what i thought....
Old 02-17-2009, 04:24 PM   #7
Chicago, IL
Michael Thomas's Avatar
wire & breaker size
Also, keep in mind that it's often a good idea to install 20 amp circuits in some situations in which a 15 amp circuit is allowed, a very typical situation I see is a "McMansion" type property with a 15 amp circuit running to a "guest" bedroom at the other end of the house from the panel, into which somebody then attempts to plug a plasma TV,a home theater sound system, a floor lamp or two, a computer - and then attempts to fire up the treadmill.
Not.
Home Inspection: ""A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
Michael Thomas is offline   Reply With Quote
Old 02-17-2009, 06:29 PM   #8
Xtreme DIY'r
wire & breaker size
I have very few 15a outlet circuits
Fridge is one, then maybe 2 pre-existing circuits
Breakers are about the same $$ for 15a or 20a - so I buy the 20a
I figure with a outlet circuit run more power is better
Old 02-17-2009, 09:37 PM   #9
wire & breaker size
yes, I agree, thanks again.... Great website..
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
wire size greywolf6 Electrical 8 07-14-2008 10:08 PM
Circuit breakers and wire size stan 41943 Electrical 19 03-06-2008 03:29 PM
Wire size for distance Question fburke Electrical 4 07-28-2007 10:29 AM
Wire Size Help-400ft line to pond for fountain brownie47854 Electrical 14 04-22-2007 01:50 PM
