Wire 12/2 Or 14/2?? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2013, 09:10 AM   #1
Wire 12/2 or 14/2??
i am going to do electrical for an enclosed screened in deck (16x25).
i want to put 9 outlets, once ceiling fan, and 8 recesses lights.
do i need a 14/2 for the outlets?
a second 14/2 for the ceiling fan (light kit) and 8 recessed lights?
or could i put it all on a 12/2??
also i plan on making fan light a three way switch, recessed not
any help wouild be great.
Kansas is offline   Reply With Quote
Old 01-12-2013, 09:19 AM   #2
Rewards Points: 13,712
I like to run all my outlets with 12-2 and a 20 amp. breaker and 14-2 with 15 amp for the lights.
Reason being that way there will not be an issue if someone wants to run an electric space heater.
Your local codes may call for an arc fault breaker.
Go back and add your location to your profile.
NJMarine (01-12-2013)
Old 01-12-2013, 09:24 AM   #3
Trucon01's Avatar
Rewards Points: 510
I took Joes advice about a month ago and ran my recessed lights on 14-2 and 9 outlets on 12-2 with 20 amp recepts for my basement project.
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 01-12-2013, 09:24 AM   #4
and will i be able to run the lights off same wire (3way for fan lights/fan) and one switch for 8 recessed lights. ?
thanks for input!!
Old 01-12-2013, 09:30 AM   #5
Trucon01's Avatar
Rewards Points: 510
Rule of 80, dont exceed and you should be fine.
15A -- 15 * 120 = 1800W * .8 = 1440W
20A -- 20 * 120 = 2400W * .8 = 1920W
Old 01-12-2013, 10:52 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
thanks for input!!
Do you mean 14/2? If so then no, you cannot run a 3-way switch with 14/2. You need 14/3.
I would also keep the lights on a 15A circuit and the receptacles on a 20A. It is MUCH easier to wire the lights/switches with #14 and there is NO reason for a 20A circuit for the lights you are running.
Old 01-12-2013, 01:31 PM   #7
i have 14/3 for the 3-way, just running 14/2 to first gang spot.
Old 01-14-2013, 03:00 PM   #8
Special User
Rewards Points: 1,230
I seem to recall something about the NEC2008 that required an extra conductor to go to a fan-rated box so that the fan could be switched separately from the light? Normally, that would be 14/3 with say black for the light and red for the fan. However, you want this light to also be a 3-way, so it's a bit more complicated than that...
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 01-14-2013, 05:12 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Good idea but not a NEC requirement.
Coastal South Carolina
connecting 14/2 wire to knob and tube pinkeo Electrical 5 04-13-2012 09:42 PM
15amp breakers, 14/2 wire, how many recepticals? mnp13 Electrical 10 11-17-2011 03:47 PM
Old 2 wire homerun splicing with new 12/2? buckman Electrical 1 09-22-2011 08:29 AM
14/2 and 12/2 together???? ryan5068 Electrical 15 02-26-2011 05:34 AM
Attaching 12/2 wire to Furring Strips blaze01 Electrical 2 02-17-2010 01:17 PM
