WIndow Sensor Triggering False Alarms - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 07:43 AM   #1
WIndow sensor triggering false alarms
One of our windows sensor is triggering false alarm every 3-4 days. I will appreciate your help to resolve the issue.
rookie8155 is offline   Reply With Quote
Old 07-23-2010, 08:02 AM   #2
Rewards Points: 320
You'll need to provide a lot more information to get help on this. Triggering a false alarm on what? A security system? A fire alarm system? What type of sensor is it? Is it a hardwired or wireless contact for a security system?
teamo is offline   Reply With Quote
Old 07-23-2010, 10:53 AM   #3
List all possible ways this can happen.
With $2 relays wired to latch on the fault you can have them babysit several test points between the sensor and the alarm indicator.
Old 07-23-2010, 11:11 AM   #4
It is a wired home alarm system (Ademco) . It is happening on one of our rear window. I cleaned window contatcs but no luck.
Old 07-23-2010, 11:12 AM   #5
Can you pry a schematic loose from Ademco and post it?
Old 07-23-2010, 03:04 PM   #6
Rewards Points: 320
What type of contact is it? Is it a magnetic contact or a mechanical button type? Can you get at the wiring from the window contact all the way back to the control panel or is it inaccessible? I would start by removing the contact and joining the wires together to see if it holds without tripping the system. If it is okay then the contact is bad. If that doesn't work I would probably go into the panel and jump out the zone at the panel and see if it holds. If that does it then the problem is in the wiring between the panel and the window contact. You may have to jump it out with a resistor if there is an end of line resistor in the zone loop. This is assuming that you have a normally closed zone.
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
False Window craleo Remodeling 1 11-18-2008 08:44 PM
