Window A/C Unit And Supplying Power - Electrical - DIY Chatroom Home Improvement Forum
Old 04-30-2011, 07:08 PM   #1
Window A/C Unit and Supplying Power
Greetings! I am installing a small window A/C unit in my apartment bedroom.
Specs on A/C Unit: 4.8 amps, 115 V, 515 watts (cooling)
The power cord for the A/C unit is too short to reach the plug. I would like to run a surge protector to make up the distance.
The cord on the A/C Unit is sized at: 3x0.824mm(squared) 18AWG.
The breaker plug on the A/C cord itself is rated at: 10 amps, 120VAC, 1200 watts.
I purchased a surge protector rated at: 15 amps, 120VAC, 1800 watts. The actual surge protector cord is sized at: 3x2.08mm(squared) 14AWG.
So I have an A/C pulling low amps on an 18AWG cord. Is it safe to say that the surge protector I have is more than adequate to handle this unit since the surge protector cord is bigger than the A/C cord? I will only be running the unit when I am home in the evenings and not all the time (weekends will vary)
Thanks for the help.
JayEnder is offline   Reply With Quote
Old 04-30-2011, 07:50 PM   #2
dSilanskas's Avatar
Yes your fine.
dSilanskas is offline   Reply With Quote
Project adding 3-phase power to a tenant finish project bnharbor Electrical 5 11-11-2010 05:39 AM
Sizing Window AC For Open Room appleye1 HVAC 17 07-29-2010 10:00 AM
New control unit, but AC still not working AiR_GuNNeR HVAC 2 06-23-2010 07:51 PM
Emergency power backup via power inverter upabove Electrical 14 06-08-2010 11:18 PM
Recepticle doesn't have enough power? slaya Electrical 4 03-14-2009 09:36 AM
