Wind Turbine For Garage Power? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2011, 01:13 PM   #1
Rewards Points: 260
Wind Turbine for Garage Power?
Hi all. I need to get electricity out to my garage. It's a detached garage and I've already had an estimate to get wires ran from my house to the garage, underground, and it was around $1025.
I was thinking about mounting a wind turbine on the peak of my garage roof and using that instead to power my garage and everything in it. Has anyone ever done this or do you know if it's a good idea? Thanks!
Jesse
jpearson311 is offline   Reply With Quote
Old 04-12-2011, 02:32 PM   #2
it would be great to power your garage with wind! (or solar)
i have built with solar power but not wind. both generate DC voltage so you would need an inverter. generator and inverter would be at least $800 for each (maybe their are small marine systems, i don't know). you would need a battery bank to store energy for non windy times.... not cheap either.
good luck
migas is offline   Reply With Quote
Old 04-12-2011, 02:50 PM   #3
Rewards Points: 260
good luck
Well, scratch that idea. Looks like I'll be burning coal. Thanks!
Jesse
Old 04-12-2011, 03:05 PM   #4
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
What kind of power do you need out there? Are you just going to run a light bulb, or do you need to use power tools? It is unlikely you are going to get much usable power from any wind system for less money than the $1,025 cost of running the wire out there.
hyunelan2 is offline   Reply With Quote
Old 04-12-2011, 03:08 PM   #5
Rewards Points: 260
I'll be using power tools too. I'd like to be able to run just about anything so I'll probably be using a 220 wire. Thanks!
Jesse
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 02:54 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 12:16 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
