Old 11-15-2012, 02:52 AM   #1
Will this work?
The switch is basically end of run.
Old 11-15-2012, 04:37 AM   #2
Electrical Contractor
kbsparky's Avatar
Will this work?
The black and white wires are reversed. White of the switch loop goes to the hot lead at the GFCI receptacle.
-KB
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
micromind (11-15-2012), sirsparksalot (11-15-2012)
Old 11-15-2012, 08:52 AM   #3
Will this work?
Or rather, the switched hot coming back to the load (light, receptacle, etc.) may not be white.
For the 2011 National Electrical Code, neutral must be taken out to the switch, necessitating, here, a 3 conductor cable. This renders academic the question of which hot conductor gets the white wire. Use red and black (doesn't matter which) for raw hot and switched hot.
The neutral is left curled up inside the switch box for future use.
Yes it will work without neutral at the switch box, given an ordinary toggle switch as opposed to a motion detector or some kinds of dimmers that need neutral to operate.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 11-15-2012, 09:54 AM   #4
A "Handy Husband"
rjniles's Avatar
Will this work?
Make sure the hot and neutral to the switch and light both come off the line or load side of the GFCI.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Old 11-15-2012, 10:14 AM   #5
Will this work?
OK, so is this the correct interpretation? Changes indicated in red.
RJ, yours is interesting; inasmuch as I don't need to use any of the LOAD side for connections? Or did I misunderstand that?
Terry
Contractor didn't start work in CT - What recourse do I have? ControlTech Off Topic 3 09-28-2010 02:45 AM
grounding the workpiece you're welding jarnold Electrical 41 09-08-2010 08:33 AM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 08:15 AM
Need help with permit/city got a Stop Work Order. amdspitfire General Discussion 39 02-07-2008 03:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 07:09 PM
