-   -   Will this work? (http://www.diychatroom.com/f18/will-work-163397/)
sirsparksalot 11-15-2012 01:52 AM
Will this work?
The switch is basically end of run.
http://i249.photobucket.com/albums/g...caltal/rls.jpg
kbsparky 11-15-2012 03:37 AM
The black and white wires are reversed. White of the switch loop goes to the hot lead at the GFCI receptacle.
AllanJ 11-15-2012 07:52 AM
Or rather, the switched hot coming back to the load (light, receptacle, etc.) may not be white.
For the 2011 National Electrical Code, neutral must be taken out to the switch, necessitating, here, a 3 conductor cable. This renders academic the question of which hot conductor gets the white wire. Use red and black (doesn't matter which) for raw hot and switched hot.
The neutral is left curled up inside the switch box for future use.
Yes it will work without neutral at the switch box, given an ordinary toggle switch as opposed to a motion detector or some kinds of dimmers that need neutral to operate.
rjniles 11-15-2012 08:54 AM
Make sure the hot and neutral to the switch and light both come off the line or load side of the GFCI.
sirsparksalot 11-15-2012 09:14 AM
OK, so is this the correct interpretation? Changes indicated in red.
RJ, yours is interesting; inasmuch as I don't need to use any of the LOAD side for connections? Or did I misunderstand that?
http://i249.photobucket.com/albums/g...rlsedited2.jpg
Terry
