Will Lowering A Bulb Wattage Blow A Fixture In Line - Electrical - DIY Chatroom Home Improvement Forum
Old 10-07-2012, 10:51 AM   #1
Will lowering a bulb wattage blow a fixture in line
I have a pool and spa light on one breaker. The spa light used a R20 100 watt bulb. It was way too bright for the size of the spa. I switched to a PAR20 50 watt bulb. Everything worked fine. I flipped it on and off a couple times as it got dark and suddenly the pool light stopped working but spa light worked fine. Thinking the pool light bulb blew, I pulled it out, tested both bulbs (MR16 75 watt) and they work. Its the fixture that isn't working. Could lowering the watts in another fixture blow a fixture on the same breaker? BTW, the breaker never tripped.
scent of a mule is offline   Reply With Quote
Old 10-07-2012, 11:13 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,822
Complicated answer.......No.....
Simple answer........No.....
Sounds like something went bad at the most unlikely time. Just be careful working around the water.
Lights on a circuit - role of bulb wattage? hyunelan2 Electrical 7 01-24-2012 01:07 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 02:56 PM
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 08:54 AM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
Bulb wattage hitmehhh Electrical 3 09-21-2008 07:59 PM
