-   -   Will lowering a bulb wattage blow a fixture in line (http://www.diychatroom.com/f18/will-lowering-bulb-wattage-blow-fixture-line-159262/)
scent of a mule 10-07-2012 10:51 AM
I have a pool and spa light on one breaker. The spa light used a R20 100 watt bulb. It was way too bright for the size of the spa. I switched to a PAR20 50 watt bulb. Everything worked fine. I flipped it on and off a couple times as it got dark and suddenly the pool light stopped working but spa light worked fine. Thinking the pool light bulb blew, I pulled it out, tested both bulbs (MR16 75 watt) and they work. Its the fixture that isn't working. Could lowering the watts in another fixture blow a fixture on the same breaker? BTW, the breaker never tripped.
ddawg16 10-07-2012 11:13 AM
Complicated answer.......No.....
Simple answer........No.....
Sounds like something went bad at the most unlikely time. Just be careful working around the water.
