Will I Need A Disconnect On My House? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2011, 08:46 AM   #1
Will i need a disconnect on my house?
400Amp meter main with 2-200a breakers on shop. 1 for the shop and the other feeding the house. Want to put the panel in the house and have nothing on the outside of the house. Can i do this or am I going to need a disconnect on the house outside? Distance from the house to the shop is roughly 75'.
??? is offline   Reply With Quote
Old 05-28-2011, 09:05 AM   #2
Rewards Points: 6,652
You are going to need a disco most likely at the meter. Check with your local AHJ.
Old 05-28-2011, 09:23 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Yes. You will one for the house panel, and the shop panel.
Old 05-28-2011, 12:03 PM   #4
Master Electrician
Rewards Points: 3,874
If your meter has main breakers as you state you will not need another disconnect. The other panel will need another main if it is located in another building.
brric is online now   Reply With Quote
Old 05-28-2011, 12:48 PM   #5
Licensed electrician
Rewards Points: 1,634
Old 05-28-2011, 12:53 PM   #6
Sparky
Rewards Points: 510
the way i read it he only has one service (400A Meter/main, 2x 200A breakers), with 2 subpanels(house, shop)
Techy is offline   Reply With Quote
Old 05-28-2011, 01:14 PM   #7
Master Electrician
Originally Posted by Jim Port View Post
And your point is? Or rather your points are?
The Following User Says Thank You to brric For This Useful Post:
Saturday Cowboy (05-28-2011)
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
