-   -   Will i need a disconnect on my house? (http://www.diychatroom.com/f18/will-i-need-disconnect-my-house-105830/)
??? 05-28-2011 08:46 AM
400Amp meter main with 2-200a breakers on shop. 1 for the shop and the other feeding the house. Want to put the panel in the house and have nothing on the outside of the house. Can i do this or am I going to need a disconnect on the house outside? Distance from the house to the shop is roughly 75'.
gregzoll 05-28-2011 09:05 AM
You are going to need a disco most likely at the meter. Check with your local AHJ.
jbfan 05-28-2011 09:23 AM
Yes. You will one for the house panel, and the shop panel.
brric 05-28-2011 12:03 PM
If your meter has main breakers as you state you will not need another disconnect. The other panel will need another main if it is located in another building.
Jim Port 05-28-2011 12:48 PM
Techy 05-28-2011 12:53 PM
the way i read it he only has one service (400A Meter/main, 2x 200A breakers), with 2 subpanels(house, shop)
brric 05-28-2011 01:14 PM
Originally Posted by Jim Port (Post 656752)
And your point is?:) Or rather your points are?
